Old 01-07-2012, 02:08 AM
highroller355 highroller355 is offline
Vehicle: 2011 ram 1500 sport crew cab
highroller355 is on a distinguished road
Default help needed will these fit
ebay link below i think it says -12mm off set my truck is a 2011 crew cab sport black, debadged, tinted,
http://cgi.ebay.com/ws/eBayISAPI.dll...ht_3273wt_1114
Old 01-07-2012, 12:17 PM
Old 01-07-2012, 12:18 PM
Old 01-08-2012, 12:47 AM
NUTSHEMI's Avatar
NUTSHEMI NUTSHEMI is offline
Vehicle: 2011 Dodge Ram
Rep:67
NUTSHEMI will become famous soon enough
No they won't. Nice tailgate What part of the island you from?
Old 01-08-2012, 01:15 AM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
If you get a leveling kit they'll fit. Not sure with it at stock height tho....
[CENTER][SIGPIC][/SIGPIC]
Old 01-08-2012, 01:23 AM
candy08 def getting leveling kit just not sure what one, but will b buying 1 this week with these rims,
nutshemi im in nassau county seaford
Old 01-08-2012, 09:10 AM
FDBDW's Avatar
FDBDW FDBDW is offline
Vehicle: 2009 Dodge Ram
Trim Level: Big Horn, 5.7 hemi
Color: BRILLANT BLACK CREW CAB
Rep:172
FDBDW has a spectacular aura aboutFDBDW has a spectacular aura about
They will rub on full lock without a level kit like Candy08 said . They stated on the add that combo is 35" , someone correct me if Im wrong but 295/70/18 is 34" . 34s will clear with a level kit but if they are 35" you may get some rub on full lock. Also your MPG reading and speedo will be off a little and there's not a programer for 2011 so you wont be able to adjust your guages for the tire size increase.
MOPAR CAI , 14" MUFFLEX, Diablo Intune 91oct , 2.5" LEVEL, K2 OPEN BLACK MESH GRILLE, FRONT WINDOWS TINTED, ROCKSTARS ON 295/70/18 NITTO TRAIL GRAPPLERS, LARADO BED COVER, DEBADGED, GO RIHNO STEPS , RECON SMOKED TAIL & THIRD BRAKE LIGHTS , PAINTED HEADLIGHTS , SPEEDLOGIX CATCH CAN, FASTMAN PORTED TB ,
Old 01-08-2012, 12:39 PM
candy08's Avatar
Rep:213
^ Yeah i wasnt sure on the stock setup. With a level even the 35.5" 295/65s clear with no rubbing. For the speedo corrction, Hypertech claims to have one that works with the 11s....
OP what level you got in mind?
Old 01-08-2012, 04:34 PM
NUTSHEMI's Avatar
Rep:67
I meant to say they wouldn't fit without a leveling kit. You should check out the regional section of the forum, alot of guys from LI. Cheeck out the Bilsteins for leveling, not only did it improve the look but they improved the ride tremendosly.
Old 01-09-2012, 01:47 AM
thanks guys and yes 34.25 height and 11.61 wide, just wasnt sure if it was correct off set
-12 i think it said at bottom of add thanks for all the input
