Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Old 09-29-2011, 10:16 AM
2011lilred's Avatar
2011lilred 2011lilred is offline
Vehicle: 2011 1500 & 2006 2500
Trim Level: Express &ThunderRoad
Color: Flame Red & White
Rep:15
2011lilred is on a distinguished road
Default 11-12 Fan Removal
I love the idea of being able to remove the big clutch fan and run with just the factory electric fans, but the 09-10 guys are using a programmer to adjust the turn-on temps. Since the 11s and 12s are not supported by a programmer, has anyone with an 11 or 12 Hemi pulled the clutch fan anyway? Results?? It's not my daily driver, nor do I tow with it.
RIP - 03 Hemi SLT QC; uncorrected 14.68 at 90.46 w/ 2.08 60ft - stolen July 06
Old 09-29-2011, 10:33 AM
Rep:1385
I wouldn't recommend it, as there would essentially be no fan (unless the AC is on). The stock electric fan only runs when the AC is on, or once the coolant reaches 222 deg F (on the verge of overheating).
Old 10-28-2011, 10:00 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
You could probably do it if you swapped in a 180 deg thermostat, at least in the cooler weather!
Old 02-27-2012, 03:52 PM
Joe7810 Joe7810 is offline
Vehicle: 2011 Ram
Color: Gray
Joe7810 is on a distinguished road
You could always install a flex-a-lite fan or something similar after pulling the clutch fan. They usually have adjustable thermostats to work with what you need.
Unless you were just looking for a freebie. Try it and let us know what happens.
Old 02-27-2012, 03:54 PM
Rep:1385
You could do it and make sure to keep an eye on your coolant temp and if it gets to 205 or above then kick on the AC compressor and then the efan will be running.....sort of a round about way but it'd work (that's essentially what mine is but the fan will come on automatically...)
Old 03-04-2012, 12:56 PM
Super12pack's Avatar
Super12pack Super12pack is offline
Vehicle: 2012 Ram 1500
Super12pack is on a distinguished road
I was thinking about running a secondary adjustable fan controller to the stock e fan. That way it would turn on with the a/c or when it reaches a certain temp. or Im also looking into running an after market push fan completely separate. still doing research so haven't decided which yet.
Old 03-07-2012, 09:16 PM
I installed on my 2012 an adjustable fan controller it works great didn't touch the thermostat clutch driven fan is removed temp has been perfect so far. i will comment once it gets to be 100 outside.
Old 03-16-2012, 05:29 PM
irnwkrkev irnwkrkev is offline
Vehicle: 2011
Trim Level: Longhorn
irnwkrkev is on a distinguished road
When it's a 100* do you drive without a/c? If not.... no controller necessary!
Old 03-16-2012, 08:03 PM
Rep:1385
I do...the only time my AC is on is if I am sitting in traffic, start sweating, and am going to something work related (can't get all sweaty in work clothes). Also on long highway trips (say 1 hr or longer...).
Fan Removal 2011lilred 2012 Dodge Ram Forum 1 09-29-2011 10:35 AM
Electric fan wiring countryb90 Heating & Cooling 5 08-26-2011 01:11 PM
4th Gen elec fan cfm? CHVYKLR Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 22 04-07-2011 05:36 PM
Electric Rad Fan panhead Dodge Ram General Discussion 10 04-01-2011 02:37 PM
Replacing Water Pump (Question) How do I remove fan from waterpump pulley MMMMDude 5.9L V8 Specific Topics 6 01-31-2011 02:12 PM
