Old 12-04-2011, 10:38 PM
dixieram dixieram is offline
Trim Level: SLT Big Horn
Color: Stone White
dixieram is on a distinguished road
Default Crew cab rear 2" drop springs
Just an FYI for anyone with a quad/crew cab. Ground force is now making 2" drop springs for our trucks It's kit #91214. Mudflaps has the best deal on them right now.
Old 12-16-2011, 09:55 PM
mikeb33's Avatar
mikeb33 mikeb33 is offline
Vehicle: 2012 1500 CC Express 4WD
Trim Level: Crew Cab Express
Rep:14
mikeb33 is on a distinguished road
I see it comes with shocks. Seems odd to need shocks at a 2" drop.
My new truck is 3" higher in the rear, do they have a kit for that?
2012 Express CC Black 4WD 3.92 Posi, Bedrug, Backflip G2, Cut rear springs, V6 fan mod, 180 thermo, Diablo Sport
Old 12-18-2011, 04:43 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Get the 2" drop and cruise that for a week or two and let the springs settle. If it's still to high in the back start cutting 1/2 a coil off at a time till you get your desired ride height
2011 Big Horn 4x4 -SnowWhite-
Old 12-20-2011, 09:24 AM
pittz5 pittz5 is offline
Vehicle: 2012 quad express
Trim Level: express
Color: mineral gray
pittz5 is on a distinguished road
when you lower the rear of a 4wd is there anything else you need to do.....like align driveline? Is it easier on truck parts then say a front level kit. obviously there is no need to align wheels. I am looking at this kit pretty seriously just not sure if there is anything else I need to watch out for. Is it hard on 4wd system? Ive search the forum but cant come up with much info.
Old 12-20-2011, 09:42 AM
Rep:1385
Lowering the rear is much better/easier on the suspension than lifting the front. Lowering the rear 2" really has no adverse effects. Granted the axle will be offset a hair due to having a panhard bar, but you're talking less than a half inch, and probably even smaller, so it's really not a big deal at all.
Also, if you cut coils I would really underestimate when you cut, as you can always cut more, but can't do anything if you cut too much. If you only need 0.5" to 1" I wouldn't cut half coils at a time I'd do more like 1/4 coils at a time.
Old 12-20-2011, 06:57 PM
ramrt1993's Avatar
ramrt1993 ramrt1993 is offline
Vehicle: 2011 Ram R/T
Trim Level: R/T
Color: Mineral Gray
Rep:69
ramrt1993 will become famous soon enough
I have a Groundforce 2" kit for my truck. The front of the truck actually becomes a little higher after the drop. My truck is only 1/2" lower in the front now. It looks 100% level.
Gatorhyde Spray In Bedliner-MGP Red Brake Caliper Covers-Tinted Windows-Partially Debadged-aFe Stage 2 Intake-180 Thermostat-Groundforce 2" Rear Drop-BT Catch Can-Fastman Throttle Body-ARH Headers 1 3/4"-True Dual 22" Magnapacks-100% Synthetic Amsoil-TYC V6 eFan-Hemifever Tune
Old 12-20-2011, 06:58 PM
ramrt1993's Avatar
Trim Level: R/T
Color: Mineral Gray
Rep:69
Oh, and I really recommend just getting the drop kit instead of cutting your coils. You get good quality shocks and springs, and its worth the money in my opinion.
Old 12-20-2011, 09:31 PM
Rep:1385
That looks great ramrt!
Old 12-20-2011, 11:18 PM
Trim Level: express
Color: mineral gray
thanks for the responses guys. Ramrt your truck looks great!! I love the level look for sure and im tired of lifted look so I really want to go the direction you did this time. snrusnak, thanks for the info, do you know if I should expect any shutter or driveline shake with it being off that little bit? I found the GF kit on Jegs for 359 and that seems pretty good. Thanks again guys
Old 12-21-2011, 07:06 AM
mikeb33's Avatar
Rep:14
$289 at Mudflaps: http://mudflaps.com/i-7251566-ground...-drop-kit.html
