Sea Foam Experiences - Page 4 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Engine Cleaning
Engine Cleaning Cleaning the Engine bay and under body. Degreasing etc.
View Poll Results: Sea Foam
Good 130 65.99%
Bad 2 1.02%
A waste 7 3.55%
Never used it 43 21.83%
What the heck is it? 15 7.61%
Voters: 197. You may not vote on this poll
Old 11-15-2013, 10:44 AM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
Personally, i would not put it in my Crankcase
motor oil has its own detergent to keep the oil passages clean
The only place that needs cleaning every once in a while, is the where the gasoline travels
I put on a Catch Can to keep motor oil out of the gasoline to keep those passages as clean as possible. The smog system puts motor oil into the combustion chambers & gunks up that area with burnt carbon, which is nothing but charred motor oil
I have never put Sea Foam in the crankcase either, for the same reason you give. While Sea Foam say's it is safe to do, and gives instructions on how to, I have read too many did not end well experiences, so another reason I have never added to the crankcase.
Old 07-07-2015, 05:25 PM
Ballast Ballast is offline
Vehicle: 2014 Ram SXT Quad Cab 4x4
Color: Granite
Rep:18
Ballast is on a distinguished road
Found it to be great gas additive in my 4 ATVS and various small engines, I also use it as a fuel stabilizer, Never tried it in a crankcase, I think synthetic oils keeps things clean and sludge-free
Old 07-07-2015, 06:10 PM
rcairflr rcairflr is offline
Vehicle: 2014 Ram 1500 4x4
Trim Level: Big Horn (Quad cab)
Color: Gray
Rep:17
rcairflr is on a distinguished road
I agree, but instead of using Seafoam I use Startron. They are great for small engines, but haven't experienced any reason to use in my truck. I had a Honda lawnmower that started running really bad so I put some Startron and Marvels Mystery oil in the gas, within a short period of time it was running as good as new. Since then, all my small engines get it.
As long as old gas doesn't stay in the tank for months on end, there is no need for it. My last truck, a F150 with 5.4 engine ran as good as new after 16.5 years of ownership and never put any additive in the gas.
Old 07-07-2015, 08:10 PM
The War Wagon's Avatar
The War Wagon The War Wagon is offline
Vehicle: 1992 Dodge Ramcharger
Trim Level: LE 150
Color: Black & Grey
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Rep:67
The War Wagon will become famous soon enough
Send a message via Yahoo to The War Wagon
Thumbs up
Did the carbon blow through the EGR on my 4.7 Jeep Commander right after I bought it; killed off the mosquitoes in the whole southern half of the county!!!
Ran so good afterward, I ran a can through my gas tank next oil change, for good measure! That was 20,000+ miles ago - probably gonna run a can with my next fuel-up this week, as I just changed the oil last week.
'92 Dodge Ramcharger... a work in progress...
'07 Jeep Commander... tow vehicle... :-p
Old 08-28-2015, 12:54 PM
dks7895 dks7895 is offline
Vehicle: 2013 Ram 1500 QC
Trim Level: Bighorn
Rep:18
dks7895 is on a distinguished road
I have done the brake booster thing on several vehicles with great results. I use it in all my chainsaws, mowers, trimmers, blowers, ATV, etc. It has been around for years and works great.
Old 09-28-2015, 10:56 AM
RayK RayK is offline
Vehicle: 2014 Ram 2500 Laramie
Rep:78
RayK will become famous soon enough
I use Sea Foam for my small engines. The cars get Chevron Techron twice a year and the truck gets fuel injector cleaner and lubricant.
Old 10-15-2015, 08:05 PM
jawzs2's Avatar
jawzs2 jawzs2 is offline
Trim Level: SLT BigHorn
jawzs2 is on a distinguished road
I use in all my vehicles for fuel, if you're looking something to put in the crankcase, Marvel Mystery Oil is the way to go. Added it to all my vehicles every third or fourth oil change, replaced about 1/2 quart of oil with it, (they say a full quart - 25% for a 5 quart change, but I'm not that adventurous). I put about a 1/4 of a million miles on a few of them, my '78 F150 300 six is the only one that ever developed a lifter tap, a full quart on the next oil change cleared it right up. Great stuff
Old 02-08-2016, 11:52 PM
Joe.G Joe.G is offline
Vehicle: 2004 SLT Hemi Quad Cab
Joe.G is on a distinguished road
I did mine yesterday, It sure did smoke a lot, but All in all i didn't notice a difference, I have added it to my Oil in all of my cars from time to time and also have ran it in the gas tank, this is the first time I put it though the vacuum port.
2004 SLT Hemi Black Quad Cab 4WD. SRT-10 Hood, 06 20 Inch Rims SC F5 Tuner, S&B CAI, Power Stop Drilled Slotted tow Package brake kit, Braided Brake Lines, Bilstein Shocks, Helwig Rear Sway Bar and G2 Axle Rear Cover, Detroit Tru Trac rear Diff,Smoked LED Tail Lights.
Old 02-10-2016, 11:02 AM
Coops's Avatar
Coops Coops is offline
Vehicle: 2014 Ram 1500 CC 4x4
Coops is on a distinguished road
I've used it in most everything I've owned. Great stuff! Never had the guts to use it in the oil though. They do make it in aerosol form now so you can clean from your TB down. Some shops even have an attachment that fits between the TB and your air cleaner and uses compressed air to spray it into your engine. Cleaned my dad's 2000 Sierra right up and stopped the TB blade from sticking.
Be prepared for lots of smoke though lol
2014 Big Horn 4x4 CC Mods: 12" antenna, Weathertech floor mats, Access Literider tonneau cover, Pypes Violator muffler, more to come...
Old 02-14-2016, 12:14 AM
monteholic's Avatar
monteholic monteholic is offline
Vehicle: 2016 Ram Power Wagon
Color: TRUE BLUE/BRILLIANT BLACK
Rep:71
monteholic will become famous soon enough
I watching some videos of this being used on engine thru a vacuum port, they showed before and after result using a bore scope thru the spark plug hole
while it removed a very small amount of carbon from the top of the pistons, you could get the same results from water the same way
ever seen a cylinder after a head gasket had blown? most of the carbon is gone compared to the other cylinders
Sam
2016 SLT Power Wagon, badge delete
