Old 12-28-2011, 06:03 PM
ram23456 ram23456 is offline
Vehicle: 2005 Dodge Ram
Trim Level: 1500 Hemi
Color: Mineral Gray
ram23456 is on a distinguished road
Default Leveling front
I have a 05 Ram 1500 2x2 and want to raise the front end. With a 2" raise, will I loose any ride quality or have to purchase higher shocks ? Also, an alignment is needed after install right ?
Old 12-28-2011, 10:04 PM
06dodge1500's Avatar
06dodge1500 06dodge1500 is offline
Vehicle: 2006 Dodge Ram
Color: Tan
Rep:13
06dodge1500 is on a distinguished road
I have a 2.5 inch level on the front of my pickup. Did not notice any lose of ride quality. You shouldn't need to buy new shocks unless the ones you have right now need replacing. I would suggest getting an alignment done after you install just to be on the safe side. Post some before and after pics so we can see the difference.
Old 12-30-2011, 06:37 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
Depending on how you level it will depend on your shock situation. If you use new steering knuckles you will not need new shocks. If you use hockey pucks on top of the springs you will likely need longer shocks as they will be extended that extra 2.5". Either way you will need an alignment afterward.
Just a suggestion, 2" typically raises the front of an 02-05 to level on all 4 corners. I have only heard of people having problems with premature ball joint wear outs on the 2.5" and above hockey puck levels.
Sure it'll suck, but it'll make you a man
Old 12-31-2011, 12:03 PM
whipinalluponya's Avatar
whipinalluponya whipinalluponya is offline
Vehicle: 2002 dodge ram 1500
Color: graphite gray
whipinalluponya is on a distinguished road
yea, if you install the polyurethane coil spacers the most you can install without needing new shocks are the 1.5'' because any bigger on a 2 wheel drive front end over extends the shocks and the ''death wobble'' can occur.
and you will want to get your front end re alined afterward, because any time you go rooting around in your front end everything gets messed up.
I got to use my AK........... today was a good day.
Old 12-31-2011, 04:57 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Stock shocks are ok to 2" but won't ride well. You won't get "death wobble" because it only happens on 4x4 with solid front axles.
IMO rough country sells a 3" "lift" kit that has new front coils and shocks with a block for the rear if you want to use it and is your best bet
Old 01-08-2012, 06:41 PM
Mulerider93's Avatar
Mulerider93 Mulerider93 is offline
Vehicle: 2011 Dodge Ram 1500
Mulerider93 is on a distinguished road
I installed a 1.5" level in front on my '06 4x2, and the ride got really stiff. Going over speed bumps was nearly a stop and crawl event. Changed to some Rancho RS5000 and the ride is back.
http://www.ramforumz.com/showthread.php?t=100815
Old 01-09-2012, 12:11 AM
JohnJ's Avatar
JohnJ JohnJ is offline
Vehicle: 2005 Dodge RAM 2500 Diesel
JohnJ is on a distinguished road
Good thread. Been considering a leveling kit but I don't want to sacrifice compfort, so think I stick w/ stock suspension and oversized tires. Thanks for the input :]>
Old 01-09-2012, 10:50 PM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
Agree. Alignment is a must anytime you do suspension work. As far as shocks go, I would replace them anytime you raise or lower a vehicle more than an inch. They don't come with a ton of travel to begin with, so shortening or increasing their travel will affect their performance and ride quality.
2007 6.7| EFI-Live | ARP | T4 S366 | AFE | Draconian tuned TCM
