Old 04-24-2012, 04:46 PM
124rr88 124rr88 is offline
Vehicle: 2010 Ram TRX4
Trim Level: TRX4
124rr88 is on a distinguished road
Why do some trucks have an aluminum driveshaft and other not?
Old 04-25-2012, 07:04 AM
BWG56's Avatar
BWG56 BWG56 is offline
Color: Mango Tango
Rep:19
BWG56 is on a distinguished road
Is this happening to the 3:92 or the 3:55 rears or both?
Old 04-25-2012, 09:13 AM
westxsrt10's Avatar
westxsrt10 westxsrt10 is offline
Vehicle: 2010 Ram 1500 4x4 Hemi
Trim Level: Cool Chrome
Color: Cool Vanilla
Rep:79
westxsrt10 will become famous soon enough
Don't know for sure but this is what I have seen...
The shorter drive shafts (like in the 4x4's) are steel.
The longer shafts are larger diameter and aluminum.
Both but.......i've seen more posts stating they had 3.92 gears.
2010 Ram CC 1500 Hemi 4x4, 3.92 Mag-Hytec diff. cover
2008 Viper coupe, Belanger ceramic headers
2008 Ford F-250 CC,4x4,V-10
Old 04-26-2012, 06:24 PM
BWG56's Avatar
Color: Mango Tango
Rep:19
thanks for reply
Old 04-27-2012, 01:50 PM
CJH's Avatar
CJH CJH is offline
Trim Level: 4 x 2
Color: Charcoal
CJH is on a distinguished road
I'm wondering if mine is getting ready to go out?
I bought the truck used 8 months ago.... 49,000 miles on her.
I've developed a "shimmy" for lack of a better word right around 40mph.
I originally thought it was electrical but the more I drive it the more I believe it is definitely mechanical.
I also have a slight " buzzing " noise when the truck is under load. I thought it was a loose exhaust pipe or heat shield...now the more I read the more I think everything is the driveshaft getting ready to go...
Also, my average MPG has dropped from over 18 down to 15....
Old 05-02-2012, 06:46 PM
TORMENTOR TORMENTOR is offline
Vehicle: 2010 Dodge ram 1500 Hemi
Color: Deep Sea Water Blue
Rep:156
TORMENTOR has a spectacular aura aboutTORMENTOR has a spectacular aura about
sounds more like your torque converter. That's another big complaint
2010 Ram 1500 Hemi Crew Cab 4x4
Bilstein 5100's maxed out, 305/55/20 Cooper Zeon LTZ's, 14" Magnaflow, K&N Drop-in, DiabloSport InTune, HemiFever tuned
Old 05-02-2012, 07:19 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Hope you all get your problems fixed for this is makin me depressed. Trying to invest in American brand again after many years and just don't know anymore. Go and read some ecoboost forums and you'll see, they too are having shifting/powertrain complaints. The madness will never cease...........
Old 05-27-2012, 09:29 PM
pistol pistol is offline
Vehicle: 2009
Trim Level: slt sport
Color: burgundy
pistol is on a distinguished road
Default 2009 ram drive shaft falls off
driving the other day, all of a sudden hear a humming sound. call local dealership to book it in for an appointment. ome minute later driveshaft falls off, rear end locks up. put in four low to drag truck off road. Apparently all pieces in my rear axel are pooched. I say that dodge might have a bit of a problem with this one. local dealership awesome, stuff happens, love my truck. by the way never put a load on it.
Old 05-28-2012, 08:59 AM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
I'm with all those that are stressing about the idea of this catastrophe happening to their truck, so I had the pinion nut checked on my truck yesterday, everything is still tight, but I am taking an extra preventative step. I spoke to a rep at a local reputable shop today and he agreed that applying a blue type of epoxy (which can be removed) to the outer threads without disturbing the pinion nut was a descent idea aiding in preventing the pinion nut from backing off for whatever reason. For me this is extra piece of mind!
Old 05-28-2012, 09:27 AM
westxsrt10's Avatar
Color: Cool Vanilla
Rep:79
Are you referring to Loctite Blue?
http://www.amazon.com/Loctite-37418-.../dp/B000FIXQXK
I have my Ram on a lift and the pinion nut can not be Loctited without removing the driveshaft.
Your Dealer should have applied the blue Loctite when they had it apart.
Photo shows where the nut is in RED...I doubt your dealer checked the nut.
