Old 05-28-2012, 08:11 PM
westxsrt10's Avatar
westxsrt10 westxsrt10 is offline
Vehicle: 2010 Ram 1500 4x4 Hemi
Trim Level: Cool Chrome
Color: Cool Vanilla
Rep:79
westxsrt10 will become famous soon enough
Photo of pinon nut location.
2010 Ram CC 1500 Hemi 4x4, 3.92 Mag-Hytec diff. cover
2008 Viper coupe, Belanger ceramic headers
2008 Ford F-250 CC,4x4,V-10
Old 05-29-2012, 08:25 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
I might have OCD, obviously Dodge isn't going to have a fix anytime soon for the pinion nut scenario, my original idea was to apply an epoxy of some sort to the threads outside of the pinion nut so as not to disturb where it was tightened to. Please share your opinions for this idea, tomorrow my truck is going for an alignment and new rear tires, at the same time they are going to expose the pinion nut, I figured if there were enough threads showing, put a second nut on with lock-tite and snug it to the existing pinion nut, I would think this would stop any movement with the existing nut. Temporary I suppose, but piece of mind. I am hauling our TT on a 5 day camping trip and I could only imagine dropping a driveshaft and the rear-end locking up on the highway.
Old 05-29-2012, 10:35 PM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
2009, 30K plus, no problems so far, knock on wood
So it is written ! So it shall be done!
Old 06-22-2012, 12:46 PM
Almond 04's Avatar
Almond 04 Almond 04 is offline
Trim Level: Big Horn SLT
Rep:30
Almond 04 is on a distinguished road
Hey guys little update. I had posted in this thread March 9th at 34K and had no problems. Well it happened to me. On vacation with the family 250mi away from home in the White Mtns of New Hampshire. Wensday June 20th all day I heard a humming when coasting not under load. Chalked it up to havin the A/C on. Then it happened boom!!! Pulled over D/S on the ground diff fluid all over the place. 39,2000 MILES ON THE CLOCK.
Pinnion nut backed off pushed the pinnion inside the carrier and locked the rear.
Called Chrysler roadside assisantce got it towed to the nearest dealer. 200 miles away from home. Dealer called yesterday needs a new D/S and everything inside the diff. Locked up solid, ripped all the teeth off the ring and pinnion crushed the spider gears too.
Dealer said all parts are on back order with no eta of arrival. Could be without my truck for 2-4 weeks. Are you ****ing kidding me??
Had to pay 117- for a cab back to the condo then 60 for a cab to the rental co. and 135 for the rental.
Called my local dlr where I bought it they couldnt gimme a rental cause there not working on my truck. He told me to call corprate and open a claim. You can bet your ass they are gonna pay for all my outta pocket expenses or I'LL SUE THE EVER LIVIN SHIT OUTTA THEM.
Cabin A/F mod / Mopar CAI / 390hp hood spears / Extang Trifecta / Custom Badges / Interior-Exterior LED's / Painted eng cover
Old 06-26-2012, 03:34 PM
CCeastside's Avatar
CCeastside CCeastside is offline
Vehicle: 2010 RAM SLT 4X4
Trim Level: SPORT CREW CAB
CCeastside is on a distinguished road
wow!!! have 40k on mine with no problem at all. and today i had the boys at the shop L,O,F, mine Ram and to check the rear end, drive shaft ect... guess what!! on the drive shaft all were finger loose!!!! hope that's all, with new hearders i just might test the DS/rear end a little more often
Old 06-26-2012, 08:26 PM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:83
Turbovsix will become famous soon enough
I just had mine in - rear pinion seal was leaking slightly, so I took it in for that and a replacement of the passenger side mirror (turning brown from the heating element!). Thank God I have the Max Care lifetime warranty.
Anyway, I was under the truck talking with the mechanic and he said that they lost a driveshaft on a dealer demo back when the 2010's were out. He had also seen a few cases on 2009's and 10's.
He checked everything, replaced the seal, etc, -
I am wondering - is it the rear that's failing which is causing the pinion nut to back off or is it the other way around?
This thread concerns me -
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI - all stock!
2012 Jeep Grand Cherokee Limited
Old 06-26-2012, 09:30 PM
scmedic09's Avatar
scmedic09 scmedic09 is offline
Vehicle: 2010 dodge ram
Color: Brillant Black
Rep:168
scmedic09 has a spectacular aura aboutscmedic09 has a spectacular aura about
man hope you have better luck, i filed complaints with chrysler canada, tried everything, but because i didnt have extended warrant/care package, what ever its called, they wont cover a rental etc. sucks a$$. mine was replaced last august, and last week went back in, bearings were screwed up due to bad dealer install. I am waiting for new gears again, because mine have wore, they said it will be about a month due to world wide shortage/back order. at least mine is still drivable. Hope you have good luck man, keep us posted
Old 06-27-2012, 12:30 AM
Rep:27
Is this happening on 2009's or just 2010s?
Is it on the 3.92 rear ends or on all?
Is it on the 4x4 or 2 wheel drives or both?
I have an 09 3.92 4x4.... With 31k miles, I crawled under mine today to have a look.... The 4, 15mm bolts that attach the drive shaft to the pinion flange were all totally tight... You can not see the pinion bolt with the unit assembled...so there is no easy way that I know of to check the pinion nut.... If anyone knows a way please let me know..
I'm about to take my truck on a vacation and don't want to have this happen and ruin my trip.... All my u-joint clips also appeared to be fine.... Thanks for any additional info
Old 06-28-2012, 04:14 AM
10ramisport's Avatar
10ramisport 10ramisport is offline
Vehicle: 2010 Dodge Ram 1500 CC
Trim Level: Sport 4x4
Rep:73
10ramisport will become famous soon enough
Otterdriver,
I thought about the same idea as well by using a second nut. Have you done this yet? Any pics? Next year I'll be moving to the lower 48 from Alaska and wouldn't want this to happen. I want some piece of mind before hand. Once I get a free weekend I might try this.
Old 06-28-2012, 04:21 AM
Rep:73
Has happened on 09s and 10s
I've read it happened on a variety of rear ends and on 4x4s/2 wheel drives
I have a 3.92 4x4 as well...knock on wood everything looks good w/20K miles
