Old 01-10-2012, 08:36 PM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
Originally Posted by TransEngineer View Post
I don't think the aeration was your problem (it was a symptom). I think your problem was a misinstalled (or loose) filter that fell out of position and then gave you no (or very little) line pressure.
Hard to say without actually seeing the parts. Did they say whether the filter was damaged (like cracked or split open), or was it just mispositioned?
This sounds a little similar to another thread that an owner had where the spin-on filter in the trans loosened or backed out on a new Ram. Hope this isn't a frequent quality control issue.
Old 01-11-2012, 04:44 AM
ram7833's Avatar
ram7833 ram7833 is offline
Vehicle: 2011 Ram outdoorsman
Trim Level: Quad Cab
ram7833 is on a distinguished road
well i'm glad to hear that this is something that is actually plausible and that the dealer isn't trying to pull a fast one on me... that being said, hopefully it's not something that is that common with the new 4th gen... it would be to bad that such a nice truck with be put together with sub par standards from the get go ...
Old 01-11-2012, 07:32 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:365
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
Originally Posted by ram7833 View Post
They seemed to say mispositioned from the factory.
I have no idea how the tranny works in the truck, but in my mind it just seems like if it was mispositionned then it just wouldn't filter properly no ? kinda like an air filter ?
No, the main sump filter has a snout that sticks up into a bore in the pump housing. If the filter is mispositioned, so that the snout comes disengaged from the pump bore, then the pump sucks AIR (from around the filter snout) rather than sucking oil (up through the snout). That gives you no drive (or very little drive).
We typically do not see issues with the spin-on (cooler return) filter (which is also inside the trans) coming loose or falling off (although I have seen a few reports). Problems with the main sump filter are much more common, although usually they result from a botched fluid and filter change (not from misinstallation at the factory).
Old 04-25-2012, 09:05 AM
RamUK RamUK is offline
Vehicle: 2013 1500
RamUK is on a distinguished road
Just had our first problem like this over here in Britain - vehicle is a 2012 Hemi Quad Cab and customer has just phoned up with what sounds like exactly the same symptoms. Vehicle will not change past 4th - rolls back even when in Drive. +/- makes it change but not as it should do
Old 01-06-2014, 05:40 PM
ram7833's Avatar
well boys, this issue just happened again over the holidays... only this time I was out about 1000 km at our hunting cabin and driving an unplowed road. everything was fine when out of a sudden the engine reved right up and the truck had no more drive. The tranny indicated 4th, but it did not move from there. Neutral on the transfer case would not come on either, gears, reverse nothing. It was -37C ... Had to get my brother to come tow me out so that to road side could come pick it up. its been in the shop for 2 weeks now and they cant figure it out. 2 Trannies in 56k ? anything that i can do here in Canada to get the truck replaced or something !?!?
Old 01-06-2014, 09:15 PM
wilhavens's Avatar
wilhavens wilhavens is offline
Vehicle: 2011 Ram 1500 Sport QCab 4x4
Trim Level: Sport Ram Box
Color: Grey
Rep:34
wilhavens is on a distinguished road
I have 74k on my 2011 and haven't had an issue with the trans... but I did have two teeth break on the rear pinon gear and i made a similar noise.
A leader without followers is just a dude walking around...
Old 01-06-2014, 10:49 PM
Trim Level: sport
Color: green
Rep:670
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
wonder if the extreme temps have anything to do with this.
Old 01-07-2014, 07:52 AM
Vehicle: N/A
Rep:365
Did they tell you what fault (or faults) you had? Have they checked the filters?
Old 02-03-2015, 10:25 PM
my hemi my hemi is offline
Vehicle: 2013 ram sport regular cab
Trim Level: sport
my hemi is on a distinguished road
Default transmission
hi i have the same trouble like you guys truck stall at a stop and they check the transmission filter and it was split obout 6 inch i will try it in the morning if its ok but before that they change the fuel pump change throttle body valve and throttle body Inside the transmission and the filter was good drove a couple days and still the same what a big lemon
Old 02-04-2015, 07:33 AM
Vehicle: N/A
Rep:365
Yes, the split sump filter is an issue we have seen on some trucks in cold weather. The new Mopar filters now have a pressure relief valve added (rubber "mushroom" pop-off on top of the filter) to prevent the split filter problem.
shift, third gear, transmission slip
