No dounuts for me! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 01-10-2012, 11:46 AM
TEXASHEMI50 TEXASHEMI50 is offline
Vehicle: 2005 Doge Ram 1500 4x4QC HEMI
Color: BLUE
TEXASHEMI50 is on a distinguished road
Default No dounuts for me!
Just had a quick question trying to see if maybe I'm just completely inept or there's something wrong with my truck of if there's a built in limiter keeping me from doing it but for the life of me 2 or 4wheel drive I can not get my back end to break loose and do dounuts in the mud it's more like squares for me the back end breaks loose mud starts flying then no power then back end brakes loose again then no power this is all withought moviving the gas pedal or even tried just mashing it to the floor and holding it there same thing! I have a 2005 Hemi 4x4 I know I've got the power it's just not letting me use it it seems like. Any advice????
Old 01-10-2012, 12:18 PM
Upstater's Avatar
Upstater Upstater is offline
Vehicle: 2010 Dodge Ram Hemi SLT 4x4
Trim Level: Bighorn
Color: Stone White
Rep:132
Upstater will become famous soon enoughUpstater will become famous soon enough
I'm not sure about a 2005 but the newer trucks have electronic traction control, and what you describe sounds like it to a tee. It's designed to keep you from losing control on the highway if one or more wheels begin to slip by transferring power from the spinning wheel and/or applying the brakes. Is there a button on your dashboard to turn it off?
If you have it, I know in my truck I can disable it in 4WD by switching into 4 wheel then holding the ETC button down for about 10 seconds.
Old 01-10-2012, 12:52 PM
AllUCIsTailLights's Avatar
AllUCIsTailLights AllUCIsTailLights is offline
Vehicle: 2007 Dodge Ram
Trim Level: 1500 Big Horn
Color: patriot blue
Rep:39
AllUCIsTailLights is on a distinguished road
Hey upstarter just open then range of suggestion.would the gear size matter what gears are you running texashemi? and also upstarter what if the tranny is slipping?
Old 01-10-2012, 01:11 PM
RamManCan RamManCan is offline
Vehicle: 2010 Ram
RamManCan is on a distinguished road
Yeah, sounds like traction control. My 2010 does it too, even with the button pushed on the dash, it will spin like crazy but as soon as the truck goes sideways it starts to brake and cuts the fuel. According to the owners manual the only way to completely disable the entire system is in low range... or so it seems to me...
Old 01-10-2012, 01:17 PM
Vehicle: 2010 Ram
Yeah, sounds like traction control to me. My 2010 does the same thing too. When I push the button on the dash all it does is let the truck spin, if it goes sideways the brakes are applied and the fuel is cut. According to my owners manual it seems as though the only way to shut it all off is in low range.
Old 01-10-2012, 02:08 PM
Color: BLUE
Yeah that's exactly what it feels like, but theres no switch anywhere to turn it off in my truck I had read somewhere that between the rear end and the rev limiter they put on the hemis it's near impossible but no one ever said what u did to fix it! Lol
Old 01-10-2012, 02:21 PM
Color: BLUE
I drive a 2011 f250 for work and it does the same thing but you have the optional button on the dash to turn it off or as y'all have said u can only minimize the effect it wi still kill the power it it notice exsessive wheel spin on the f250. Shurley there is a way to disconnect or timporarilly disable really makes for a bummer time out in the pits when all u can do it go slow and steady! Lol
Old 01-10-2012, 03:24 PM
Rep:2954
things that i found
ESP push and hold will let it slip depending on the steering input but as soon as the wheels spin more than 65km/h (40mph) it will start do it's thing.
For 4X4 owners only, go to post #20
http://www.ramforumz.com/showthread.php?t=42153&page=2
Old 01-10-2012, 03:54 PM
Color: BLUE
looks like my only option is a programmer seeing as how theres no buttons on my 05 to turn this option off
