Old 01-10-2012, 03:46 PM
camoman214 camoman214 is offline
Vehicle: None right now
camoman214 is on a distinguished road
Default High Engine Idle
1999 Ram, 5.9L, auto, 4x4
I just replaced the IAC valve on my truck 'cause it wouldn't idle and figured the IAC was bad. Now the truck idles at 1800 rpm and I can't get it to idle down to normal. I did the proper IAC adjustment which calls for driving at 40 mph to allow ECM to learn the setting. I unhooked the battery for a few days hoping it would reset the ECM, that didn't work. I took the NEW IAC back to the parts store and exchanged it for another one, still idles at 1800. What else should I check? I didn't see any vacuum leaks.
Thanks for your help.
Old 01-12-2012, 02:05 PM
Stein's Avatar
Stein Stein is offline
Vehicle: 1999 Dodge Ram 1500 4x4
Trim Level: SLT Laramie
Stein is on a distinguished road
try the (TPS) throttle position sensor I had some some idle isues on my 99 5.9 4x4. you can test them with a meter I don't have one so I just replaced the IAC and the tps and that fixed it. the iac came out in 2 pieces so I know that part was bad not sure on the tps. but the tps was 33 dollars and I replaced both within a 1/2 hr. and only spent about 70 for both. I use my Haynes for almost everything. but you can set up a free account at autozone and they have alot of helpful info on there as part local,diagrams,how to test, and what type of symtoms a failing part can cause
Old 01-12-2012, 03:41 PM
I had figured the next thing I would try would be the TPS. I got one from Advance Auto Parts for under $30, so I'll slap that in and see how she reacts. Sometimes these trial and error steps can start costing a pretty good amount of money.
I'm gonna be putting it up for sale soon and it needs to be idling okay first. lol
Old 01-12-2012, 11:44 PM
Stein - you hit it right on the head. Replaced the TPS and now it runs like new again.
Thanks for the quick and only reply.
Old 01-13-2012, 08:18 AM
Stein's Avatar
your welcome, I'm no mechanic and I hate the trial and air thing to. mine didn't throw an engine code for either sensor. I have a cheap scanner witch has helped alot exept for that, but I knew I had to be somewhere in the ballpark. and without the code pretty much everywhere around here wanted $70-90 just to look at it, I've never had any sensors replaced on it and with 102,000 miles I figured what have I got to lose. so glad I was able to help, this forum is great I've saved alot of money reading stuff on here. the only thing I have paid to have done are my front axle shaft seals, mainly because it's winter and she wont fit in my garage, or I would have tried them to.
Old 01-13-2012, 10:20 PM
Well I guess I spoke too soon. After replacing the TPS sensor and driving the truck last night, the truck ran fine and idled normal. Today, I started it up and now it's idling high again, just as it was before.
Old 01-14-2012, 12:18 PM
Stein's Avatar
that sucks, did you reset again after you put in new tps
Old 01-16-2012, 01:32 AM
I unhooked the battery again today for 12 hours to reset the ECM after the new TPS was installed. Still idles high between 1100 and 1600. Any other possibilities?
Old 01-28-2012, 04:51 PM
evilsack's Avatar
evilsack evilsack is offline
Vehicle: 1994 Ram 2500 5.9L 360 4x4
evilsack is on a distinguished road
Default re
I had the same issue going on and found that my throttle cable itself was frayed and got caughtup which made it not release completely (resulting in higher idle).
I actually resolved this issue after nearly killing myself when it stayed full throttle and wouldnt free up, i nearly went through someone house.
Old 01-31-2012, 12:57 AM
Donmega884's Avatar
Donmega884 Donmega884 is offline
Vehicle: 1998 Dodge Ram 1500 5.9 4X2
Donmega884 is on a distinguished road
Have you ever tried taking out the throttle body off the manifold and making sure you clean the entire part with carb cleaner? I know it's a very cheap way too find the problem first. Also you can clean an IAC and make sure the tip is completely free of carb. Always remember to try and find the exact problem first, never throw money at and engine and hope for the best.
Sean
