Old 01-11-2012, 07:42 PM
RTBenny RTBenny is offline
Vehicle: 2012 Ram R/T
RTBenny is on a distinguished road
No, unless your SS/T was fairly extensively modded or either your R/T is broken, it wouldn't stand a chance. Those trucks are lucky to run 15s stock. Also, put those tiny 17s on your R/T and roast away. Or vice versa, put your 22s on a 5.9 and they will kill it. And I've had two of them so I know what I'm talking about.
2013 F-150 King Ranch 4wd 5.0
Old 01-11-2012, 08:55 PM
DWWHemiguy's Avatar
DWWHemiguy DWWHemiguy is offline
Vehicle: 2012 Ram
Trim Level: Express Quad Cab
Rep:37
DWWHemiguy is on a distinguished road
Originally Posted by jmr View Post
Press the traction control button on the dash then a squiggly line icon will appear on the instrument cluster. Then stomp on it and and let us know how much rubber you burned. My wimpy little '12 Express with limited slip and 3.55 gears will spin with no problems on dry pavement.
x2 I have the same set up and mine will do the same.Maybe yours has a tranny issue of some sort.
Old 01-11-2012, 09:02 PM
moparornocar72's Avatar
Rep:630
before my tuner and other mods were installed mine would spin with just a magnaflow muffler on it.
14.268 @ 95 MPH Full Trim
Old 01-11-2012, 09:04 PM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
But jmr, we have your home-grown dual inlet air intake mod and an aftermarket muffler on our Express', so we're probably turning 10-second 1/4 miles at the moment...LOL!
But seriously, I'm in almost exactly the same boat as your Express with the gearing and LSD. Turn off the traction control and it'll spin those big 20's. In fact it can give you a bit of a scare when you let off, and the tires get a full bite and the truck isn't exactly straight. This truck will pin you to the seat under full throttle. It's a hoot.
Old 01-11-2012, 11:03 PM
RamMan16 RamMan16 is offline
Vehicle: 2012 Dodge Ram 1500 Big Horn
RamMan16 is on a distinguished road
sounds like it may be a flux-capacitor issue... I had a problem with mine on my delorean...
just kidding... my tires will chirp a little from a dead stop (have 3.92s) with the traction control turned off... otherwise it will just pull hard...
2012 Ram 1500 Big Horn - K&N CAI - Line-EX - Bestop Tonneu - Rockstars - Trail Grapplers
Old 01-11-2012, 11:15 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
push the one with the picture of the car that looks like to ss behind it to disable traction control
Old 01-12-2012, 09:54 AM
edwardzed edwardzed is offline
Vehicle: 2012 Ram
Trim Level: R/T
edwardzed is on a distinguished road
I found the traction control button yesterday but it rained all day and there were no dry pavements anywhere.
I will give it a shot today once the school buses and traffic ease up.
Let me throw one more wrinkle in: While driving I can rev the engine and let up, and watch the rpms go up, and the trans does not respond. If I hold the accelerator down, after some lag time the trans responds.
As far as the user manual, a hard copy did not come with the truck. Instead there was a CD. Inserting the CD would cause my computer to crash (instant "blue screen"). When I talked to Chrysler they said that this happens a lot. COL (Cry Out Loud)
Old 01-12-2012, 10:51 AM
TNC TNC is offline
Rep:12
I wonder if it's possible that you're experiencing some of the trans slipping mentioned recently where the one of the two internal filters are either improperly installed, came loose, or have a failure that's allowing fluid pressure to drop? While this is apparently not common, it's been reported on at least two recent threads.
On your observation that you see rpm's rise while stomping on the gas, are you sure you're not slipping the tires? Wheelspin doesn't always result in the hollywood tire squealing and smoky burnout situation that you might expect, depending on conditions at the time. I'm not saying that you indeed may not have a mechanical issue, just trying to think of all the possibilities.
Old 01-12-2012, 12:20 PM
Vehicle: 2012 Ram
Trim Level: R/T
IT'S A BRAVE NEW WORLD!!!
I LOVE MY TRUCK!!!
I took the traction control off and it is a different truck. Tire spin and acceleration, I love it.
I only had time for a quick test. Will check it out fully later.
I want to thank every one that responded to this post for their help. I was shooting in the dark (no owners manual, new technologies, first new truck in 13 years. etc.) and now I can see the light at the end of the tunnel.
I can see I have a lot to learn about the new technologies. I have been playing with a 1969 Mercury Marauder 429, 360 HP for the last 10 years, which is a whole different world and, I guess, it affected my expectations. Have patience with me, still learning.
Again (except for the first 3 respondants to this post) thanks to all, I greatly appreciate it.
Ed
Old 01-12-2012, 08:39 PM
DWWHemiguy's Avatar
Vehicle: 2012 Ram
Rep:37
Glad it worked out. How about a pic of the 69 Merc when you have a chance? I would like to see it.
