Old 01-10-2012, 06:01 PM
two4ruff's Avatar
two4ruff two4ruff is offline
Vehicle: 2011 Ram 2500 Crew Cab 4x4
two4ruff is on a distinguished road
Default 2011 Back Up Camera Relocation
I'd like to get an ARE MX canopy with the walk-in back door http://www.4are.com/product/walkin/ which replaces the tailgate. The problem is I have the OEM back up camera set up. Is there a way to get a different camera to work with the 430 radio? I'd like to install one on the canopy to use when I have the canopy on and leave the OEM unit on the tailgate for use when I don't have the canopy on.
Old 01-10-2012, 07:15 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
You might be able to get one of the license plate bracket camera, or mount it down on the bumper some way! Not too sure on this one!
Old 01-10-2012, 07:27 PM
BlueX6 BlueX6 is offline
Vehicle: 2011 Dodge Ram Sport
Color: Hunter Green Pearl
BlueX6 is on a distinguished road
Did you look at the Lockpick V4?
Old 01-10-2012, 07:35 PM
Rep:2620
some of the radio after market units
allow you to have a front & rear camera, others allow more than 2
just install one of those devices & use the front camera on the trucks canopy
check out ALLGIG & Lockpick websites for starters
Old 01-19-2012, 11:16 PM
aeroshots's Avatar
aeroshots aeroshots is offline
aeroshots is on a distinguished road
Default 2 or 3 back up cameras
I am looking into something simular. I remove my tailgate to install a slide in camper. Would like to install a camera on the back of the camper and connect to the quick disconnect plug exposed with the tail gate removed. Anyone see issues with this?
Old 01-22-2012, 08:16 PM
welr welr is offline
Color: Gray / Sandstone
welr is on a distinguished road
Default Been looking
Ditto on the slide in camper. Checked with Dodge and they have nothing and couldn't tell me if I could splice in a cable to a factory unit to extend it to the back of the camper. Sure would like to see a wiring diagram to see if its possable to make my own camera and mount it on top of the camper and be able to see over the back of the bike trailer.
Old 01-22-2012, 08:53 PM
Rep:2620
this was stolen from a different forum
mygig lockpick. Hook that to the radio and it gives you rca input to hook the camera up to the factory radio. That allows you to watch the camera while you're driving also
Allgig setup, ask for Suzanne, to get discount
http://www.navtv.com/product/174/all...eShowProduct=1
http://www.navtv.com/search.php?acti...roductPriceTo=
Lockpick setup
http://www.coastaletech.com/LOCKPICK_CAMERAS.htm
http://www.coastaletech.com/MYGIG.htm
Old 01-22-2012, 09:26 PM
united316 united316 is offline
Vehicle: 2011 Dodge Ram Crew Cab SLT
Rep:87
united316 will become famous soon enough
This is a write up I have been studying for when i replace my pop up with a 26 or 30 foot TT. It might help you out some.. but I don't know.
http://www.2manytoyz.com/backupcam.html
2011 SLT Crew Cab 4x2, 4.7, 3.55 gears, TruXedo TruXport Soft Roll-Up Dual Latch Tonneau, Westin Black Platinum series oval step bars, Aeroskin Hood Protector, Ventvisors In-channel smoke , Husky Liners Front ard Rear Mud Guards, K&N drop in air filter.
Last edited by united316; 01-23-2012 at 11:01 AM. Reason: for some reason the link did not post.
Old 01-22-2012, 11:15 PM
aeroshots's Avatar
Default Camper
I have a small chepo camera that I will experiment with. Seem like if the wiring is already at the tailgate then there should be some sort of plug and play camera. I do like the aftermarket multi camera options too, but don't need that if simply relocating one camera is all that is needed at this time.
Old 01-23-2012, 12:36 AM
Thanks aeroshots intersted too see what you come up with. Also like the plug and ply units that GTyankee posted. Really like the overrides for the gps and other stuff for the long trips.
