heater blowing cold - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 01-11-2012, 12:29 PM
Gearhead Gearhead is offline
Vehicle: Dodge ram 2002
Color: Blue
Gearhead is on a distinguished road
Default heater blowing cold
Okay guys I'm a bit confused here, the climate control knob is on heat, the truck is at normal temp, it blows air but it isn't pleasant with this cold Texas weather, there isn't any moisture or wet content on the floorboard from the heater core. Just not understanding why it still blows but not heat?!!? Do you guys think that my system is clogged?? (corroded)
If it's got tits or wheels, it will give you problems.
P-Funk
Old 01-13-2012, 10:21 PM
Parkerram Parkerram is offline
Vehicle: 1997 ram ss/t
Trim Level: SS/T
Parkerram is on a distinguished road
probibly a plugged heater core. you can try flushing it .
Old 01-13-2012, 10:27 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1276
Couple things to try, first would be to backflush the heater core if that doesn't work make sure that the blend door is opening correctly. Not sure how to do it on an 02, hopefully someone will chime in with some better instructions on how to check that.
Big Red my old 2011 Sport
Old 01-15-2012, 12:35 AM
ricksbuells ricksbuells is offline
Vehicle: 2002 4dr 4x4
Trim Level: SLT LARAMIE
Color: BLACK
ricksbuells is on a distinguished road
I just finished putting a new heater core in my 2002 ram with a 5 speed,only took 19 hours to do it.It started out by blowing luke warm air,then to a puddle in my floorboard.Definetly flush it out.The blend door is tricky to get at ,its behind the glove box and you still have to take apart the dash to get to it.Be careful the dash will crumble.
Old 01-15-2012, 04:13 AM
Rep:2920
Check out YOUTUBE
type HEATERTREATER
you find loads of info, just start watching, you WILL find your answer
Old 01-17-2012, 04:12 AM
Camarata's Avatar
Camarata Camarata is offline
Vehicle: 2003 Dodge Ram 1500
Color: Green
Camarata is on a distinguished road
I was having the same problem with my 03 last year except I also had problems with the air flow, it seemed even at full blow that it wasn't that strong. It ended up being the heater core. It wasn't leaking inside the cab but I could smell anti-freeze when I would turn on the heat. I also noticed after about a month that my anti freeze was down a tad. My mechanic first flushed the system and it worked great, didn't notice any leak so we thought we fixed it. After a couple of days I was back to cold air. Checked the thermostat and nothing so I ended up forking out the money and replaced the heater core. A year later I still have nice warm and steady heat.
Old 01-17-2012, 10:39 AM
Color: Blue
In reference to (Camarata)
Yeah man that's crazy that you mentioned that because every once in a while when I turn the heater on, I smell anti-freeze, I heard the heater core was only like 50-60 bucks, not to bad I'm just afraid of the repair as far as taking the dash out!
Ricksbuells: So what do you mean when you say the dash will crumble? The blend door, are these the doors that open up to front vents or dash vents? Because if I want to put it on a certain vent, like defrost or floor only, I hear clicking and stuff but never adjust to my desired choice, it stays on defrost.
Stomp3r: How do you back flush a heater core?
P-Funk
Old 01-17-2012, 10:40 AM
Color: Blue
P-Funk
Old 01-17-2012, 01:45 PM
Camarata's Avatar
Color: Green
Exactly, the price of the heater core isn't bad it's dealing with your dash that sucks. Since its not just a quick fix. You might as well check the door while you have the dash off. I couldn't tell you where everything is at but there are a lot of great guys on here with endless info. If you smell a little anti freeze once in a while, check to see if the reservoir is a little down compared to normal or if you have any residue starting to form on the windshield. Tell take sign of a bad heater core.. Hope you figure it out. Nothing worse than having air blow out but it being cold instead of hot.
If you aren't losing any anti freeze or seeing any residue or moisture on the floor(which I wasn't I could only smell it) it would be a lot cheaper / time efficient to just flush the system.
Keep us posted!
Old 01-24-2012, 10:00 AM
Color: BLACK
If you are not careful the dash breaks apart really easy like they are ate up from being exposed to the elements. The blend door and the other vent doors are in a black box behind your glove box.They all have acuator motors on them ,there are 3 of them and you have to remove the dash to get to them .If you are hearing clicking I would say that one is slipping through the gears and not opening.I cut a rectangular hole in my firewall right at the heater core hoses and made a cover from sheet metal that can be removed. The heater core lays flat and is held by 1 screw now I can remove it in 5 min. start to finish.Why can't the factory do this from the start? Hope this helps, it took me alot of time learning the hard way.
