Engine overheating after replacing thermostat w no leaks - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Diesel Forums!
Dodge Caliber
Old 07-24-2017, 07:39 PM
Pistolpete3008 Pistolpete3008 is offline
Vehicle: 2002 Dodge Ram 1500 4.7L
Color: Blacj
Pistolpete3008 is on a distinguished road
Default Engine overheating after replacing thermostat w no leaks
I was having issues with overheating with no leaks to be found other than boiling out of the radiator cap. I replaced the cap and thermostat and still having issues. Still no leaks. Any ideas on what to do next?
Old Yesterday, 08:05 AM
airforce26yrs's Avatar
airforce26yrs airforce26yrs is offline
Vehicle: 2017 1500 Sport CC
Color: Copper Edition
Rep:59
airforce26yrs will become famous soon enough
System could be plugged up. Try reverse flushing the system. I had a '69 charger that this happened to. Was having overheating issues and after I sold the car the next owner said he had to reverse flush it to get rid of the problem. Now how you do this is a mystery to me. I would assume that you would hook up a hose to the heater hoses somehow to get the reverse flow. Good luck.
Old Yesterday, 01:11 PM
300m's Avatar
300m 300m is offline
Vehicle: 2013 Ram Sport
Color: deep cherry red
Rep:29
300m is on a distinguished road
The engine produces heat, and the radiator reduces heat; the only thing in between is the thermostat; if it fails to open, you'll overheat; you've already replaced the thermostat with no results; it's fair to assume the thermostat is not faulty (but not 100%; I've seen new thermostat not work); the next thing causing overheating would be air in the engine/radiator; if the water level in the engine is too low, the pump cannot pump it into the rad. ( it's not a pump, it's only a "water circulator) Bleed with the cap off( keep adding water) at operating temp., AND at higher than idle RPM.
Next, could be the pump not working at all or only partially; when the pump is working, the 2 heater hoses will be hot, as the pump circulates water through the heater as soon as the engine is started; if both hoses are cold when the engine has warmed up, the pump is not working, or the water level in the engine is really low.
Lastly as mentioned in the above post, is a plugged up rad. or partially plugged; if the lower rad. hose is cold or barely warm, either the pump is no good or the rad. is restricted.
If you get lots of heat from the heater, the pump is working.
With the cap off, and the engine full of water, you should get lots of water movement at above idle speed, with the thermostat opened, if the pump is working.
The only purpose of the cap, is to pressurise the rad./engine/heater, so the water will boil at a higher temp., preventing premature overheating. There should always be some water in the overflow reservoir; that's the excess water when the temp. goes up; it is sucked back in the rad. once cooled off.
Good luck
