Old 01-11-2012, 11:08 PM
MF2000's Avatar
MF2000 MF2000 is offline
Vehicle: 2009 Ram Crew Cab
Color: Inferno Red
Rep:13
MF2000 is on a distinguished road
Default Strange issue
I owned the truck for almost two weeks now and love it, but I noticed an unusual problem. There is a small,white plastic solenoid behind the glove box that started ticking at random times.
Today, a few minutes after leaving work it started ticking and never stopped. I'm not sure what it controls, but looks like a flapper control for the ventilation. I didn't have the a/c, heat, fan or anything on when it started. I first tried turning the fan on then rotated to higher speeds....no luck...it continued. I switched the control from vents to defroster stopping every position in between....no luck....it continued. I tried switching the a/c on...no luck. I ended up pulling off the road and unplugging the clip that supplies power to it and it stopped. The controls all appear to function normally still. My truck is still under warranty and I plan to take it there to get it repaired but I'm trying to understand what it is and why it's doing it.
Anyone else have this issue?
Old 01-11-2012, 11:12 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
That's the geiger counter, it ticks when your not driving the hemi hard enough
I have no idea what that solenoid could be for. Any chance of a pic of the little ticker?
Big Red my old 2011 Sport
Old 01-11-2012, 11:13 PM
moparornocar72's Avatar
Rep:630
they had a flash/update for the hvac, ur truck might be under it and solve that issue!
14.268 @ 95 MPH Full Trim
Old 01-11-2012, 11:56 PM
Ram10tuff Ram10tuff is offline
Vehicle: 2010 Ram CC
Ram10tuff is on a distinguished road
Flux Capicator.... Dont mess with it it produces 1.3 jigga watts of electricity. Sorry bud i had to. No clue what it could be
Old 01-12-2012, 12:00 AM
Rep:630
I would call the dealer and give them ur VIN they should be able to tell u if needs to be flashed for that HVAC update/issue and if ur truck isnt under that category then I would take it to the dealer and have them fix it under warranty if it still is
Old 01-12-2012, 12:29 AM
Rep:2616
I bet it is the K 17 recall issue
Recall notice is "Customer Satisfaction Notification K17" and covers 2009 and 2010 models.
http://www.dodge.com/webselfservice/pdf/K17.pdf
Old 01-12-2012, 10:07 AM
337ram 337ram is offline
Vehicle: 2009 1500 4x4
Color: grey
Rep:15
337ram is on a distinguished road
Is it a ticking or more of a knocking noise???? My 09 just started doing this, it sounds like someone is knocking on the plastic where the front cup holders are at on center of console. is this what yours is doing???? Samething no ac/heat on etc
Old 01-12-2012, 11:28 PM
MF2000's Avatar
Color: Inferno Red
Rep:13
I believe this is the issue. I took a video of it clicking but I'm not sure how to post it here.
I have an appointment to take it to the local dealer to get it fixed monday.
Thanks for the help guys....you all rock!
Old 01-12-2012, 11:39 PM
MF2000's Avatar
Color: Inferno Red
Rep:13
It's a loud, annoying tick that is one constant speed. If you remove your glove box and look up and to the left, you'll find it. It kinda stands out because it's the only white plastic around there. I think the guys nailed this one.
Old 01-13-2012, 04:10 AM
Airdog's Avatar
Airdog Airdog is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Sport 4x4
Color: Detonator Yellow
Rep:37
Airdog is on a distinguished road
It sounds like a "blend door actuator" or another actuator in the A/C system. The software update may fix it but your Ram may also require the actuator to be replaced. Mine was updated in October and also required the actuator to be replaced. Fortunately, I never had a problem with the a/c prior to the recall. Fixed at the dealer no charge.
~Airdog .
