Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 01-12-2012, 12:46 AM
BIG HORNS BIG HORNS is offline
Rep:31
BIG HORNS is on a distinguished road
Default 4th Gen Ram - Drag Launching in "4wd Auto"
Hello all, just bought an 11 QC 4x4 with 3.55s and 20's. Just put 6 runs on her at the track, with no mods my truck went 15.24 with only slight wheel spin launching at about 1200 rpm then nailing it.
Since there are mods to come and traction was pretty good that day, I am looking for feedback on launching in 4wd Auto.
I did not want to attempt full throttle launches in 4wd Auto until I got some advice, but with an open rear end, street tires and more power to come it makes sense to research the subject. Thanks for any input you may have. JIM
BIG HORNS: looking for a "14" best ET so far is 15.24 @ 91.89 showroom stock.
Old 01-12-2012, 11:32 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Try not to load the TC just stomp on it from idle when you load the TC it pulls timming. Also use auto stick it will run much smoother. Just put it in first at the line and as soon as u launch shift it to 2nd then as soon as it shifts to 2nd put it in 3rd and so forth. I bet you will have 14's in the bag doing it this way! Also go ahead and remove your air filter and your tail gate for the track only of course.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 01-13-2012, 12:29 AM
Rep:31
Thanks for the reply RAMTEX, tried the launch (hard to find a patch of pavement without snow) and it definitely jumped out harder, I used the manual shift button for my fastest runs at the track this past fall, but was shifting as the tach hit 5300. Shifting early and letting the tranny do its thing was a far easier deal to get the same results. Hope I don't kill the transfer case with the harder launches LOL. Thanks again, JIM
Old 01-13-2012, 11:02 AM
RamTex's Avatar
Color: Stone White
Rep:366
As far as the 1/8 mile is concerned you should be ok running it out in 4x4 but 1/4 wise it may be more beneficial to launch in 4x4 and imediately switch to 2wd once you get out of the whole. It must be done soon or you will be goin faster than 50mph and i cant garrentee bad things wont happen... You will also see a big differrence at the other end of the track as well.
Old 01-13-2012, 11:22 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
4 Auto will only engage the front tires when it is needed, there a few people that ALWAYS drag their trucks in 4 auto with good results!
Old 01-13-2012, 09:04 PM
I push the skinny pedal
Rep:3277
I notice a drop of about 4 tenths when I run in 4wd, the transfer case takes a lot of power to turn the front wheels. It's better to stick to 2wd, drop some air from your tires, and hammer if from line without loading the TC. Only launch in 4wd if a) you run a diesel that has the high torque to turn everything properly b) you have terrible traction issues c) you just want to.
Kurtis
Old 01-13-2012, 09:29 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
I killed a Tundra on my second attempt in 4WD auto. My first attempt he got the jump on me and I just spun the rear tires. It definitely comes out of the hole quicker in 4WD auto with the 3:55 rear end. I had the auto stick set to 3 and just let it shift on it's own. I did have the SC 91 tune installed at the time. Heres my thread on the kill -> http://www.ramforumz.com/showthread.php?t=93796 .
Old 01-13-2012, 10:19 PM
Rep:31
Great feedback guys, can't wait until this winter crap dies out, by May I will be moving to within an hour of an 1/8 mile track close to Kingston Ontario ( almost right across from Syracuse NY) and I will put all the advice to the test ! And I do have a kill story actually, I should post it I guess, Thanks All, JIM
Old 01-16-2012, 04:25 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
TRy launching about 3-400 RPMs off idle... Thats always worked best with my truck in 4Auto
2011 Big Horn 4x4 -SnowWhite-
Old 02-01-2012, 01:28 PM
semichigan's Avatar
semichigan semichigan is offline
Vehicle: 2004
Rep:48
semichigan is on a distinguished road
Send a message via AIM to semichigan
its the only way i race my 04 stroker
