Blower motor - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 01-12-2012, 10:35 AM
CJ.2007Ram's Avatar
CJ.2007Ram CJ.2007Ram is offline
Vehicle: 2007 Dodge Ram 1500 4x4 Q-cab
Trim Level: SLT Big Horn
Rep:28
CJ.2007Ram is on a distinguished road
Default Blower motor
I have noticed a few people on here mentioning that their blower motors will work only on high. Mine either works or doesn't. There is no odd sounds such as squeaking, grinding, etc. The blower will run fine for a while then it begins to taper off then quit; after a while it will start up again. Should I replace the motor or is there another issue I should check first?
Old 01-12-2012, 01:21 PM
09nitetrain 09nitetrain is offline
Vehicle: 2006 raqm 1500 trx4 hemi
Trim Level: trx4
Color: blue
Rep:20
09nitetrain is on a distinguished road
there is a resistor card that controls the speed of motor, usually if the motor has high resistance it will burn out the card. when i replace the resistor card i always recommend doing the blower motor if not there usually back in a few months for another resistor and the motor at that point
Old 01-12-2012, 07:33 PM
CJ.2007Ram's Avatar
Rep:28
Where is this resistor card located? Is it a difficult replacement? And thank you for the advice.
Old 01-12-2012, 07:38 PM
Trim Level: trx4
Color: blue
Rep:20
look up from where from the passenger feet would go under the dash, hope this would help
Old 01-13-2012, 03:47 PM
CJ.2007Ram's Avatar
Rep:28
Thanks! Much appreciated!
Old 02-21-2012, 12:54 PM
dan42474 dan42474 is offline
Vehicle: 2002 dodge ram 1500 4x4
Color: silver
dan42474 is on a distinguished road
hey guys im glad to have found this forum i have a 2002 ram 1500 and the blower motor quit working on it, i have tried both a resistor and a blower motor and niether seems to fix it, i only have 9 volts at the blower motor i thought it should have run on that alone but it wont, the only other thing i can think of is the blower motor switch, fuses are good and i can not find a relay for it pleeeease help
