Place your Ad Here!
Old 01-12-2012, 10:48 AM
Biggesthorn's Avatar
Biggesthorn Biggesthorn is offline
Vehicle: 2009 dodge ram
Trim Level: Bighorn
Rep:14
Biggesthorn is on a distinguished road
Default 38s on a daily without damageing drivetrain?
Im wanting to put 38s on my 2010 ram I have 35"nitto muds now but I just want to go bigger if not 38" muds im going to go to a 355/60r20 terra grappler (nearly a 37) I dont want to damage anything transmission wise thou....do u think with the right gears the trans will hold up?
5" lift 35" mud grapplers 20x12 fuel hostages rbp grille rbp steps nfab front and rearrunners
Old 01-13-2012, 12:40 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Gears would be helpful, what ratio do you have right now? It can be expensive to do a 4wd truck!
Old 01-13-2012, 05:53 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
If you're going 37+ get some 4.56s
What setup do you have to run 38" mud graps?
[CENTER][SIGPIC][/SIGPIC]
Old 01-13-2012, 09:41 PM
Rep:3337
I agree with the 4.56 if you're thinking 37-38. With that gear rato you should have no problems with the tranny, though I always recommend a shift kit simply because there's lots that can be done to improve the stock tranny.
Old 01-16-2012, 10:38 AM
Trim Level: Bighorn
Rep:14
6" rc 3" pa body and blisten adjustables is going to be my setup....if i decide to go 355/60r20 terra grapplers ill prob go without the adjustables.....ive also been looking into duratrack tires...i like the meaty look but i drive interstate everyday to go to work and my current mud graps are holding up surprisingly well been 2 month and theyve shown no wear (bought them used right about to hit wear bars and there still at the same depth i bought them as)....i bought them used because taxes are buying the 6" rc lift....right now im running the pa 5"....anyway i plan on doing 4.56 gears in the rear should i run the same up front??? i hardly use 4wd ever....and if i do its just for a few seconds....trucks only seen wet clay in the driveway into a mudbog....what shiftkit would be good ?
Old 01-16-2012, 11:23 AM
Schmitz's Avatar
Schmitz Schmitz is offline
Vehicle: 2005 Dodge Ram 2500 4x4 QC LB
Schmitz is on a distinguished road
Yes run the same gears in the front you never change gear ratio in just one or the other
2005 Dodge 2500 4x4 QC LB Hemi, 6 inch lift, 37" Cooper Discoverer STT's, Bully Dog programmer, K&N cold air intake performance throttle body, true duals, debadged.... Soon to come 4.56s and wheels, maybe more lift.
1980 Chevy K20 4x4 9 inches of lift 37" Boggers, 402 BBC, 4 spd, D60, 14ff.
Old 01-16-2012, 11:39 AM
Trim Level: Bighorn
Rep:14
alright thats what i thought now i know its the 9.25 rearend but what front diff comes in the 1500 4th gens????
Old 01-17-2012, 10:10 AM
DVSk8er DVSk8er is offline
Vehicle: 2010 Dodoge Ram 1500
Color: Inferno Red
DVSk8er is on a distinguished road
it is a 8.0 ifs front. i run 4.56's with 38x15.5's daily. i have over 15000 miles on this setup and tow regularly over 6000lbs with no issues
Old 01-17-2012, 10:17 AM
Trim Level: Bighorn
Rep:14
Saweet looks like im running 4.56s and 38s thanks everybody for replying so fast
Old 01-18-2012, 07:21 PM
2011 ASSAULT 800's Avatar
Trim Level: Quad Cab Sport
Rep:251
just remember, pics or it didnt happen!
