Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 01-12-2012, 12:00 PM
RamRoy RamRoy is offline
Vehicle: 2014 Dodge Ram
Trim Level: BigHorn
Color: Deep Cherry
Rep:15
RamRoy is on a distinguished road
Default Driver side mirror installation help
I am replacing the driver side mirror assembly. It was kissed so lovingly by an extended trailor mirror from another truck. I took off the inside molding that is on the opposite side of the window from the mirror. It was easy...just pull it off to get to the nuts that hold the mirror assembly to the door. It looks like I have to pull off the door panel to get to the power connections though. Is that door panel a pain? Will I need to buy replacement clips?
Old 01-12-2012, 01:30 PM
Trim Level: BigHorn
Color: Deep Cherry
Rep:15
I found it. With pictures and everything. It also tells you how to remove the window.
Oh...and heads up, I got a guaranteed "after market" power/heated/turn signal mirror assembly for $83. The local dealership wanted $372!
http://www.ramforumz.com/showthread.php?t=66244
Old 01-12-2012, 02:11 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Pulling the door panel is easy, I just changed my exterior door handles, so if you have any questions just let me know!
