Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Body & Interior
Old 01-01-2012, 02:21 PM
ru223l ru223l is offline
Vehicle: 2006 Dodge Ram
ru223l is on a distinguished road
Default Removing the bed and finding a part
Hey all. I had the infamous p0456 and p0457 codes on my new to me 06 Ram 1500 4.7 and I started doing some looking around and found that the culprit is the small hose that goes from the cap directly on the tank to the filler neck. With that being said, does anyone know exactly what it takes to slide the bed off (6.5') and where if I can even get that cap without buying a whole new tank? Unfortunately, I don't have a junk yard near buy to just pick one up from there. The nipple that the hose slides onto is broken and that is why I need that dang cap! Thanks in advance!
'06 1500 QC 4.7L
Old 01-01-2012, 02:49 PM
Now that I am looking, is that the top of the fuel pump that seals off the fuel tank?
Edit: I just looked under there and it is not the fuel pump, its closer to the cab than the fuel pump. Looks like it just has a couple of hoses plugged into it.
'06 1500 QC 4.7L
Old 01-01-2012, 03:41 PM
Rep:2657
I am only guessing from experience with other trucks, mostly Chevy
Usually there is a electrical pigtail, that the wiring harness for the bed plugs into, up close to the firewall, around the steering column
Then 6 or 8 bolts holding the bed to the frame
Then 4 people could lift it off or move it enough to access the gas tank
Or if the tank is close to empty, you could try dropping it out from under
Look at LMC truck online for the part(s)
http://www.lmctruck.com/icatalog/de/full.aspx?page=107
http://www.rockauto.com/catalog/moreinfo.php?pk=2720798
http://www.jimsautoparts.com/mopar_p...uel_parts.html, good images of parts
you may have to call around & find the part & make a 50 mile trip to a wrecking yard
GOOD LUCK
Old 01-02-2012, 10:29 AM
It's a sad day for me. Apparently that piece that is broken is part of the gas tank itself and can not be replaced... $500 something from the dealer. They also quoted me $62.50 for the emblem on the grille. For that cost, I might as well have a custom one made...
'06 1500 QC 4.7L
Old 01-06-2012, 06:54 AM
UberRam's Avatar
UberRam UberRam is offline
Vehicle: 2005 Dodge Ram QC 4x4
Trim Level: Daytona
Color: GoMango
UberRam is on a distinguished road
For that price it may be worth driving to the nearest junk yard. I know you can get a gas tank from them for about $75 (and even get a 34 gallon if you want to upgrade). Not sure if you know about this site but it works pretty good: http://www.car-part.com
Old 01-06-2012, 07:09 AM
Thanks for that website. I had looked at another website similar to that and was unsuccessful. I found a tank about an hour away from me that will do the trick!
'06 1500 QC 4.7L
Old 01-11-2012, 07:53 PM
I finished this up today. I picked up a used fuel tank yesterday and a new fuel pump today and threw it in the truck. It's amazing how much easier it is to work underneath the truck when you have a lift to put it on! Thanks for the help everyone!
'06 1500 QC 4.7L
