Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 > Exhaust
Exhaust 4.7L Exhaust Discussion
Old 01-12-2012, 02:42 PM
Darkknight3829's Avatar
Darkknight3829 Darkknight3829 is offline
Color: Gloss Black
Rep:141
Darkknight3829 will become famous soon enoughDarkknight3829 will become famous soon enough
Default Custom Exhaust
Thinking of doing my own custom design to my exhaust with a summitracing universal kit. welding straight from the CATS and angling right out just behind the front wheels. Your thoughts?
Check out my mod thread!= http://www.ramforumz.com/showthread.php?p=709872&posted=1#post709872
AirAid Intake System, PowerAid Throttle body spacer, SuperChips Flashpaq, Edge RacingTorque Converter, Straight Through Exhaust, Mechanical fan delete, ATI Super Damper, MT Street ET Drag Radial Tires
Old 01-12-2012, 03:11 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Is it necessary to have 3 separate threads about this? LOL
Having a crossover (such as an x pipe, h pipe, or even y pipe) is actually benefitial to performance. Having the exhaust run out and exit just behind the front wheels, without having a crossover, would perform worse than if you had a free flowing exhaust with a crossover and free flowing muffler.
Sean
Old 01-12-2012, 04:57 PM
Color: Gloss Black
Rep:141
LMAO no just to have different peoples opinions that may not see it because they don't have a 4.7L or a 2010 :-)
Old 01-12-2012, 05:00 PM
Color: Gloss Black
Rep:141
Explain? If you don't mind
Old 01-12-2012, 07:16 PM
snrusnak's Avatar
Rep:1385
I'll use a y pipe as an example since they are most common on our trucks:
Exhaust flow is not constant, it comes from the cylinders in pulses (if you think about it it makes sense). When you have two exhaust pipe that merge to one (and they are of sufficient diameter as to not cause restriction) what happens is the exhaust pulse from one bank of cylinders travels down and passes the y pipe junction, and as it passes the junction it "sucks" the next exhaust pulse coming from the other bank of cylinders. They call this scavenging, and it actually can help "suck" the exhaust out of the engine, improving flow and performance. The restrictions on this are that all the pipes must be properly sized. For our trucks, the oem sizes are about perfect (2.5" downpipes merging into a single 3" pipe).
Typically, an x pipe is better than an h pipe, which is better than a y pipe. But in reality, they are all about equal.
Sean
Old 01-13-2012, 09:30 AM
Color: Gloss Black
Rep:141
That makes sense. Hmm learn something New everyday. Thanks a lot for the explanation! Maybe i can customize an x pipe under there. I kind of have an idea how im going to make it work.
Old 01-13-2012, 09:32 AM
Color: Gloss Black
Rep:141
I dont like now the stock exhaust SMASHES the Y pipe under the trans. Thats HORSEPOWER BEING TAKEN AWAY!!!!!!!!!!!!!! that needs to be ELIMINATED
Old 01-13-2012, 09:33 AM
snrusnak's Avatar
Rep:1385
There is a member (with a 3rd gen I think) that did an x pipe setup right behind the transmission. Nice setup and will perform well, but IMO it's about the same as a y pipe, and much more material and labor ($$$), and heavier. IMO the extra weight will offset the couple hp gained.
Sean
Old 01-13-2012, 09:45 AM
Color: Gloss Black
Rep:141
Ok, So Ill go with a custom Y pipe design. Probably buy some 3 inch pipes from summit and cut/weld myself.
Old 01-13-2012, 09:48 AM
snrusnak's Avatar
Rep:1385
You could go with an aftermarket Y pipe, magnaflow makes one it is stamped and flows well. Flowmaster also has a good one, among others. I think it is like $30, probably easier/cheaper than making your own.
Some do an x pipe with both pipes on the passenger side, but again to me at the end of the day it's equal to the y pipe setup...
Sean
