Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 > Exhaust
Exhaust 4.7L Exhaust Discussion
United Radio
Old 01-13-2012, 10:51 AM
Darkknight3829's Avatar
Darkknight3829 Darkknight3829 is offline
Color: Gloss Black
Rep:141
Darkknight3829 will become famous soon enoughDarkknight3829 will become famous soon enough
They manufacture them for the 2010 4.7L?
Check out my mod thread!= http://www.ramforumz.com/showthread.php?p=709872&posted=1#post709872
AirAid Intake System, PowerAid Throttle body spacer, SuperChips Flashpaq, Edge RacingTorque Converter, Straight Through Exhaust, Mechanical fan delete, ATI Super Damper, MT Street ET Drag Radial Tires
Old 01-13-2012, 11:09 AM
Color: Gloss Black
Rep:141
There is a member (with a 3rd gen I think) that did an x pipe setup right behind the transmission. Nice setup and will perform well, but IMO it's about the same as a y pipe, and much more material and labor ($$$), and heavier. IMO the extra weight will offset the couple hp gained.
Forgot to mention! I want to stick with the tailpipes exiting behind the front wheels. So i think the only option i'd have with that besides exiting straight out would be the X pipe. Even if the x pipe is possible im VERY limited on space.
Old 01-13-2012, 11:15 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
It's more of a "universal" part. You'd have to clamp or weld it in (most weld it in).
If you want the pipes to exit behind the front wheels an H pipe is probably the only crossover you could do, and honestly even then it's probably not real doable. Having the pipes exit behind the rear wheels, or just behind the doors is probably more likely and doable with an H or X pipe.
Sean
Old 01-13-2012, 11:27 AM
Color: Gloss Black
Rep:141
Ya i noticed that probably be a lot easier. But i wanted to do something that i Havent seen on a street vehicle but if its impossible. Then ill go with the exit in front of the rear wheels.
Old 01-13-2012, 11:33 AM
snrusnak's Avatar
Rep:1385
You could get crazy like on the old LT-engine corvettes and do some weird exhaust routing(the manifolds actually faced the front of the vehicle, then the exhaust curved back around) but still don't know if there is enough room or any way to really do it.
Sean
Old 01-13-2012, 11:53 AM
Color: Gloss Black
Rep:141
Ha! That be WICKED. This weekend ill check out the spacing again and see what i have to play with. It probably generate a little more heat under the hood dont you think?
Old 01-13-2012, 11:55 AM
snrusnak's Avatar
Rep:1385
Yeah it'd probably create more under hood heat.
Sean
Old 01-13-2012, 12:06 PM
Color: Gloss Black
Rep:141
I like the idea though. They do sell the U turn arounds for that. They come in universal kits.
Old 01-13-2012, 12:08 PM
snrusnak's Avatar
Rep:1385
I'm wondering if there's any room to run the exhaust basically straight down, and have an H pipe under the engine/trans and then run them out behind the front tires. I don't think there is though....recalling from memory the cross member is in the way, and right behind that is the oil pan drain plug...
Sean
Old 01-13-2012, 12:52 PM
Color: Gloss Black
Rep:141
The cross beam sits a little back and i believe it is out of the way for what i had in mind. I wanted to run down from the cats just a little then angle and cross right away and head straight out behind the front tires. Left manifold exhaust exits the right of the truck and the right manifold exhaust exits the left of the truck
