Old 01-12-2012, 07:56 PM
Bigdiezel79 Bigdiezel79 is offline
Bigdiezel79 is on a distinguished road
Default 2010 4.7
Guys I have a 2010 4wd crew cab I plan on pulling my 2 horse trailer with it. What mods would you all consider would be the most help to me for towing engine wise? Im not sure how the rear coil spring suspension is gonna do with the weight either.
Old 01-12-2012, 09:54 PM
dig dig is offline
Vehicle: 2010 1500 Dodge Ram Crew Cab
Trim Level: SLT- Big Horn
Rep:25
dig is on a distinguished road
Default Rear springs
This may help
Total Load Control
login | cart | checkout
Order Here: Inquiries Welcome
Home > Dodge Ram 1500 Coil-Spring ('09-'11) > TLC for Dodge Ram Coil-Spring Rear Suspension
MSRP: $799.00
Price: $599.00 New Year's Special
Item Number: DCS-1551
Quantity:
Total Load Control is the only rear suspension enhancement designed for 1/2-ton pickups that uses full-size 9-inch air springs. The lifting power and cushioning properties of the air springs combine to boost hauling and towing capabilities, dramatically improve handling and stability and provide the best air-cushioned ride ever.
Why do you need Total Load Control? The stock suspension simply cannot handle all the forces that you encounter driving in the real world. While all other pickups have a simple leaf-spring rear suspension (the design of which hasn't changed since the 1950s), the 2009 and later RAM 1500 has a coil-spring suspension. That's why hauling or towing really heavy loads makes the back end sag and the front tires lift, creating steering difficulties, uncertain handling and a rough ride. Total Load Control eliminates all those problems and keeps your truck level and safe.
But TLC adds something more Total Safety. Inflating TLC's air springs pushes the front tires down to virtually eliminate oversteer and understeer. TLC also tightens the back end and reduces body roll. With TLC engaged, you'll have a feeling and reality of total control of your truck and whatever you're hauling or towing.
Each Total Load Control kit comes fully equipped with air springs, precision-manufactured steel components, custom-built control panel for in-cab manual operation, all air fittings, hardware, wiring kit, and installation instructions for on-demand operation (optional air compressor sold separately).
Old 01-12-2012, 10:19 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
What is the weight of the trailer (loaded)? Dependin on your gearing and wheel/tire combination, your towing capacity changes. It basically ranges from 6,000 lb at the low end to 7,000 lb at the high end. If you have 20" wheels and 3.55 gears it's likely the low end, and if you have 17" wheels with 3.92 gears it's likely the high end. Make sure to use tow/haul mode when towing loads as it will help save the torque converter clutch, and aid in "drive-ability" when passing or such.
I highly recommend a superchips flashpaq (roughly $350.00) as it will actually improve your mpg and has many options like 93 octane performance tune (adds 67 lb ft of torque max) and tow tunes (it helps a lot, I have used it). The tow tune helps protect the engine by retarding timing, and helps towing in general by giving you more torque at lower rpm's and holding gears longer. They actually change the shift schedules in their tunes. It's by far the best bang/buck mod.
Sean
Old 01-13-2012, 11:40 PM
The total weight is gonna be close to 7000. I have 17 inch rims unsure about what gears are in this truck. My first dodge pick up so Im not up to date on what gear they like to run
Old 01-14-2012, 09:18 AM
snrusnak's Avatar
Rep:1385
Total trailer weight = 7000 lb or total combined weight = 7000 lb?
Sean
Old 01-14-2012, 08:20 PM
trailer with 2 horses 6675.. I have 3.55 gears...
Old 01-15-2012, 10:50 AM
snrusnak's Avatar
Rep:1385
That's about the max for that truck (actually I think the max is 6,250). I've hooked up more to mine and it pulled it ok, but I wouldn't do it often or in hilly areas, etc...
Sean
Old 01-15-2012, 04:32 PM
Yeah thats what i was figuring once i went to the scales... Gonna have to find another option for hauling. But i am still gonna get a CAI, Programmer, and exhaust upgrade. And the leveling kit. Might just sell the horses for more horses in my truck.
Old 01-15-2012, 09:35 PM
snrusnak's Avatar
Rep:1385
Yeah that's pushing it. I tow in excess of my rating sometimes, but I do so on the superchips tow tune that gives more torque, and I do it rarely, and for short distances (and I'm in FL so no hills).
Sean
Old 01-16-2012, 11:22 AM
Darkknight3829's Avatar
Darkknight3829 Darkknight3829 is offline
Color: Gloss Black
Rep:141
Darkknight3829 will become famous soon enoughDarkknight3829 will become famous soon enough
Add as much low-end torque as you can. Horsepower is out of the question for something like this. I believe Hughes has a towing Torque Converter that would work really well.
Check out my mod thread!= http://www.ramforumz.com/showthread.php?p=709872&posted=1#post709872
AirAid Intake System, PowerAid Throttle body spacer, SuperChips Flashpaq, Edge RacingTorque Converter, Straight Through Exhaust, Mechanical fan delete, ATI Super Damper, MT Street ET Drag Radial Tires
