Old 01-13-2012, 12:17 PM
CanuckHRAM's Avatar
CanuckHRAM CanuckHRAM is offline
Vehicle: 2011 Ram Quad Cab 4 x 4
Trim Level: SLT Outdoorsman
Color: Deep Water Blue Pearl
CanuckHRAM is on a distinguished road
In the winter, I always let my vehicles run for a minute or two before driving off. Living in Canada where the temperatures in my area can easily hit -40 or colder with the wind chill, I feel this is important to allow the oil to properly circulate in the engine. I also always put the tranny in Drive and let it sit in Drive for a few seconds before backing up. Not sure if this is still required on newer vehicles but a Tranny Shop Owner once told me years ago that this really helps the life of an Auto Tranny as the Tranny Oil Pump does not work in reverse so an immediate back-up would not circulate oil properly.
Raider Phantom Topper, K&N Drop-In Air Filter, Vent Visors, SmittyBilt Light Bar & PIAA Lights
Old 01-13-2012, 12:48 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Just an FYI this is incorrect. If the engine is running (and everything is working properly), then the engine turns the flywheel which turns the torque converter which turns the trans oil pump, so it doesn't matter what gear you're in, it is pumping.
Sean
Old 01-14-2012, 08:48 AM
Dancianne's Avatar
Dancianne Dancianne is offline
Vehicle: 2011 Dodge Ram, Quad Cab
Trim Level: ST with combo packag
Rep:136
Dancianne will become famous soon enoughDancianne will become famous soon enough
Thanks to all !
Like some of you, I do put it in gear upon startup and just hold the brake while waiting, both to flow transmission fluid as well as bring down initial rpms. But if covered with ice/snow, I chicken out and wait in the house for a few minutes.
Sean, the Harley is injected, and rpms do drop very quickly. While I never ride below 60 degrees, that diet of 20w50 is a thick pour and I like to feel a warm crankcase platecover. My ancient vette though,...just like you said.
Condensation, contaminants and other byproducts: Short trips in cold weather are a fact of life for probably many of us. Possible diluted
oil?....yes, but I recently read that only about 30 minutes of continuous driving once per month generates sufficient heat to drive off any buildup of contaminants.
Dancianne
Old 01-14-2012, 10:17 AM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
Originally Posted by 65Arboc View Post
HeyBrownDog
Without the oil companies you would not be driving ANYTHING!
Jim in Pa
LOL! So true!
Old 01-14-2012, 11:28 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I always hit the remote start as I'm walking toward my truck so it is idled down by time I get in and buckle up. In the winter, I warm it up for a short while to ensure the oil is flowing easily in both the engine and trans, then drive moderately for the first few minutes. Unless I'm being a suck about the cold, or the windows are frosted badly on the inside, I never let it warm up for more than about 2 minutes in -30deg temps.
brad
Interested in one of my mods?
Old 01-14-2012, 12:20 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
i usually hit the remot start before i go out in winter but im off and driving before the first 15 min run time is up
Old 01-14-2012, 12:42 PM
09nitetrain 09nitetrain is offline
Vehicle: 2006 raqm 1500 trx4 hemi
Trim Level: trx4
Color: blue
Rep:20
09nitetrain is on a distinguished road
winter time i let the remote start go for about 5mins, then get in it and go, my harley i coast down the drive way, fire it up, granted its fuel injected but with 583 lift cams, head work and high compression its still real stumbly till fully warmed up, but i idle up the road to the stop sign where the main road is and sit for an extra few minutes. my end of the street i got all the old crotchy people live around me. the durango use to piss them off. custom 3 inch exhaust and single chamber flowmaster.
Old 01-14-2012, 02:32 PM
squig69 squig69 is offline
Vehicle: 15 quad cab
Trim Level: sxt
Color: granite metallic crystal
Rep:13
squig69 is on a distinguished road
i usually warm it up a few minutes in the winter to help take the "cold" out of the cab area, i like it warm when i get in and drive. with symthetic oil in it shouldnt the oil be circulating almost immediately? so for me its just to get into a warm cab
things out of square make me cry
Old 01-14-2012, 02:56 PM
johnnymopar's Avatar
johnnymopar johnnymopar is offline
Vehicle: 1998 in between truck GM 1500
johnnymopar is on a distinguished road
My 98 GMC with 225,000 miles on it needs to warm up in cold weather for about 5 min to get rid of a knock, then its fine (lifter ticking?). In warmer weather (above 3 degrees Celsius) I just warm it up for about 1-2 minute before I drive off, keeping the revs low for the first 5 minutes or so.
Old 01-14-2012, 03:06 PM
snrusnak's Avatar
Rep:1385
^yeah most likely a lifter. Once my s10 hit 200,000 miles it developed a lifter tick on cold mornings, it would go away after a minute.
Sean
