Cooling fan run full time - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 01-13-2012, 09:22 AM
ZeroZero3's Avatar
ZeroZero3 ZeroZero3 is offline
Vehicle: 1999 Dodge Ram
ZeroZero3 is on a distinguished road
Default Cooling fan run full time
Hi guys, I only own the truck for a little bit but I noticed that the cooling fan is running full time and it's getting colder and colder here. Any Idea? fan itself seems alright.Thanks
Old 01-13-2012, 10:06 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
You're talking about the engine cooling fan right? And I assume it's a mechanical fan with a clutch? It is likely the clutch that is faulty.
Sean
Old 01-13-2012, 06:42 PM
ZeroZero3's Avatar
I read somewhere that dodges fan are running 1000 rpm all the time, is that right? And yes it's the engine cooling fan.
Old 01-13-2012, 07:41 PM
charlieb's Avatar
charlieb charlieb is offline
Vehicle: 2017 ram express quad cab
Trim Level: express
Rep:37
charlieb is on a distinguished road
zero i had the same question that didnt clearly get answered for me,so i asked a mechanic he explained when you start your vehicle the fan turns when your at a stand still (even when its cold)if u start driving the faster you drive the more the clutch fan will slip until it warms up and the clutch fan will grab more the hotter it gets weather your moving or not.long story short when its not running you should be able to turn the clutch fan by hand.
Old 01-13-2012, 11:57 PM
ZeroZero3's Avatar
Alright, thanks charlieb, fan is turning by hand like you said and I will pay attention when I am driving around if it's running. What I was reading was on a 94 Ram and I never found anything else to confirm it.
