Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 01-13-2012, 04:17 PM
RamRoy RamRoy is offline
Vehicle: 2014 Dodge Ram
Trim Level: BigHorn
Color: Deep Cherry
Rep:15
RamRoy is on a distinguished road
Default Mildewy Vent smell
When it rains and I have the defrost or heater on...I get an odd smell from the vents. Kinda wet mildewy type smell. Anybody have that issue or know what it's from? I have a 2010 with 29500 on it.
Old 01-13-2012, 11:02 PM
LC Hauler's Avatar
LC Hauler LC Hauler is offline
Vehicle: 2014 Ram 2500 Laramie
Color: Bright Metalic Grey
Rep:72
LC Hauler will become famous soon enough
that is the AC, I have noticed the same in my car when I run the defrost. My advice is to use the defrost every day when you drive the truck on high heat /low fan, and that will help get that mildewy smell away. Because technically the AC mixes with the heat when you use defrost that smells tends to produce some moisture in the ducting.
I note this more in my car as I park it for the winter, so I just run it for about 20 mins with the defrost on full hilt during the winter every month or so. Pretty much takes care of h mildew smell.
Old 01-14-2012, 05:24 AM
daggertats daggertats is offline
Vehicle: 2011 ram reg cab 4x4
Trim Level: st
Color: deep water blue pearl coat
Rep:14
daggertats is on a distinguished road
they make a spray that you can put into the vent system to get rid of that odor. had this issue on a different vehicle yrs ago and the spray helped.
Old 06-08-2012, 06:01 PM
pain601's Avatar
pain601 pain601 is offline
Vehicle: 2012 Ram 1500
Trim Level: Lone Star
pain601 is on a distinguished road
Hello I also have been having this problem, however its a little different for me. I only get it when it rains. When i open the door to my truck it smells right away. I turn on the ac then it goes away. it only happens when it rains and it last for two days.
Old 06-09-2012, 12:43 PM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
On a side suggestion......piss anyone off lately while driving? Maybe someone poured something in your cowl on the outside too. I have heard of that happening. Would definetly have a smell that happened.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 06-10-2012, 02:15 PM
MWO Sean's Avatar
MWO Sean MWO Sean is offline
Vehicle: 2011 Ram Big Horn Crew Cab
Color: Blue
MWO Sean is on a distinguished road
Mine does the same - smells like my Grandmother's basement. It does go away within minutes of having the fan on though.
