Old 01-13-2012, 08:33 PM
ZRcatman's Avatar
ZRcatman ZRcatman is offline
Vehicle: 2006 Ram Laramie
ZRcatman is on a distinguished road
Default REC w/lockpick in 2006 Laramie
Just got done installing an REC nav radio with lockpick and aftermarket rear camara, Everything is pretty straight forword in instructions. I'll take it out Saturday for drive to triangulate the navigation, You just have to make sure all wiring you need for your application is hooked up before you plug lockpick up with power otherwise you have to unplug to switch things.
Old 01-26-2012, 10:43 AM
ZRcatman's Avatar
Default REC w\ lockpick UPdate
I have had my truck to dealer for the airbag light tripping on and off, And after it was determined that the LOCKPICK was the culprit and unplugging it from harness problem went away. Talked to tech from oemautoparts I found out the lockpick was having problems they are working with coastaletech who made the pick. So here I sit waiting.
