Any harm in running in tow/haul mode when not towing or hauling? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 4.7L (287 cu in) PowerTech V8 Specific Topics
Old 01-14-2012, 01:14 PM
darowden's Avatar
darowden darowden is offline
Vehicle: 2011 Dodge Ram Crew Cab
Color: Deep Water Blue Pearl
darowden is on a distinguished road
Default Any harm in running in tow/haul mode when not towing or hauling?
Sometimes my 4.7 seems a bit sluggish in busy traffic and tow/haul mode really perks it up. My understanding is basically I am bumping up my gear ratio by punching the button, and I will burn more gas, but other than that, does anyone think it hurts anything to use the tow haul mode when desired and not just when towing and hauling?
Old 01-14-2012, 02:37 PM
IN2H2O's Avatar
IN2H2O IN2H2O is offline
Vehicle: 2017 Ram 1500
Trim Level: Limited
Color: Pearl White
Rep:100
IN2H2O will become famous soon enoughIN2H2O will become famous soon enough
I do the same thing. It increases rpm but if the vehicle is not loaded down, I can't see it doing any harm.
Old 01-15-2012, 10:42 AM
darowden's Avatar
Yeah, I figure it just change the ratio since the RPMs seem about 200 RPM higher on the tach accross the board.
Old 01-17-2012, 11:54 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:518
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
Tow/Haul mode alters the shift schedule, not the actual gear ratios, but this makes it easier to get a kickdown (to a lower gear) and may hold you in a lower gear longer as you accelerate.
No, there is no problem with driving it all the time in Tow/Haul mode, if that's what you like.
Old 01-20-2012, 06:53 PM
darowden's Avatar
It just seems like in standard mode there is a slight lag between first and second gear.
Old 02-07-2012, 08:43 PM
jjz28's Avatar
jjz28 jjz28 is offline
Vehicle: 2007 1500 4.7
Trim Level: SLT TRX4 Offroad
Color: grey
jjz28 is on a distinguished road
I know what you mean, it seems like you have to push down the gas too far to get it to kick down and then when it does, it is actually too much acceleration then. I wonder if a tuner would help with this problem?
Old 12-23-2012, 11:51 PM
mr61impala mr61impala is offline
Vehicle: 2010 ram
Color: grey
mr61impala is on a distinguished road
Default Tow Haul
When I'm running the steeper mountains of eastern Ky. I have used tow/haul to reduce the amount of shifting. Is more relaxing? and does not seem to negatively affect the fuel consumption.
Old 12-28-2012, 11:14 AM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
TE, not trying to argue with you, but I swear that my truck in T/H yields the same exact rpm to speed in top gear that shifting from 6th to 5th yields. I can cruise down the highway in top gear (6th) and manually shift to 5th. It's about a 200 rpm rise. Then I can cruise down the highway in top gear and punch T/H, and it goes to the same 200 rpm rise. In either scenario it holds that rpm to speed, so it's not a kickdown effect. Now my '12 Express is a hemi, but isn't the tranny the same with either engine?...basically?
I agree on the quicker downshifts and the tranny holding a gear longer while accelerating with T/H.
Old 12-28-2012, 12:08 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
To clarify what TE said above:
In normal driving(transmission in "D" with T/H mode OFF) the transmission will upshift as follows:
1st
3rd
4th
5th
6th
You can see it skips the 2nd gear. Yes I know it's actually called 2nd prime, but it's a million times easier to just say it's a 6 speed. the 545rfe "5 speed" and the 65rfe are for all intensive purposes identical. They have the same 6 forward gear ratios. And yes the 4.7L and 5.7L share the same transmission.
When in T/H mode, the transmission will upshift as follows:
1st
2nd
3rd
4th
5th
Hope this clarifies it a bit.
Sean
Old 04-18-2013, 02:53 PM
terrydaktal terrydaktal is offline
Vehicle: 2012 Ram 1500
Trim Level: SLT 4x4
Color: silver
terrydaktal is on a distinguished road
Good info thank you for sharing.
