Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 4.7L (287 cu in) PowerTech V8 Specific Topics
Old 04-18-2013, 02:58 PM
LowcountryHemi's Avatar
LowcountryHemi LowcountryHemi is offline
Vehicle: 2007 Dodge Ram 1500
Rep:23
LowcountryHemi is on a distinguished road
To clarify what TE said above:
In normal driving(transmission in "D" with T/H mode OFF) the transmission will upshift as follows:
1st
3rd
4th
5th
6th
You can see it skips the 2nd gear. Yes I know it's actually called 2nd prime, but it's a million times easier to just say it's a 6 speed. the 545rfe "5 speed" and the 65rfe are for all intensive purposes identical. They have the same 6 forward gear ratios. And yes the 4.7L and 5.7L share the same transmission.
When in T/H mode, the transmission will upshift as follows:
1st
2nd
3rd
4th
5th
Hope this clarifies it a bit.
Thanks for sharing!!
I swear I've learned more about my truck in the past week I've been on this board than I have in almost the year I've had it.
Old 04-18-2013, 11:10 PM
terrydaktal terrydaktal is offline
Vehicle: 2012 Ram 1500
Trim Level: SLT 4x4
Color: silver
terrydaktal is on a distinguished road
I tried this out when I got home From work today, and when you are in T/H mode your truck doesn't switch to ECO so the throttle response it better.
Old 04-22-2013, 08:35 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^FYI "eco" mode doesn't do anything, it's just a glorified vacuum gauge. At least with the 4.7L anyway, I'm not sure if with the hemi it means it's in MDS mode.
Sean
Old 04-22-2013, 07:40 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Yup, thats all it is, as snrusnak says, its just that a gloridied vacuum gauge, Same thing with the hemi, it just indicates your driving the truck in the most Eco way, even you disable the MDS it will still show you Eco when the vacuum sensor see's its not working hard.
Old 05-05-2013, 07:23 PM
izzy's Avatar
izzy izzy is offline
Vehicle: 2012 Dodge Ram
izzy is on a distinguished road
thank god you guys said that i was under the impression that when the ECO popped up on my dash it meant i was loosing cylinders..good to know that the T/H mode disables that..anyone care to elaborate exaclty what that ECO indication means what do you mean by glorified vaccum gauge?
Old 05-05-2013, 07:41 PM
snrusnak's Avatar
Rep:1385
It means you are driving in a fuel efficient manner(light throttle).
Sean
