Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 01-14-2012, 02:23 PM
ckkohn92 ckkohn92 is offline
Vehicle: 1997 Dodge Ram
Trim Level: SLT Laramie
Color: Dark Green
ckkohn92 is on a distinguished road
Default Heater Core Questions
i am looking to replace my heater core i believe there is a leak in is somewhere my windshield gets foggy with the truck at full operating temp heat all the way on blower motor on high and defrost and the side windows get a lot of condensation on them so basically im driving like this . it takes a while for the heat to begin coming from the vents and it is not HOT its just kinda warm until its been running for a LONG time i have looked into a Chilton and it says i have to drain the A/C system and remove the lines! is this true and is there any EASIER way to do it or any helpful pointers so i can make this SEMI easy thanks in advance
Corey
Old 01-14-2012, 11:54 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
In order to change the heater core you will need to remove the entire heater box from the truck. The heater box includes the A/C evaporater so you will need to remove the A/C charge and remove the high and low pressure lines going into the evaporator at the firewall. I did this once on an 89 Caravan, it's a big job but doable if you take your time. You will need to take it somewhere when your done to recharge your A/C.
Old 02-04-2012, 05:12 AM
Nitro1 Nitro1 is offline
Vehicle: 96 dodge ram 3500. 4x4
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Nitro1 is on a distinguished road
Get your self a repair book at auto zone . on my 96 ram had to get heater core from inside , had pull the whole dash out on mine. Part was cheep. alot of work . but look at bright side you get to see your dodge with no dash. cool . Good luck
Old 02-04-2012, 08:12 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
It is quite a treat to see your truck all taken apart. Also a treat once the jobs done and for only 1/2 the cost of a shop doing it.
Sure it'll suck, but it'll make you a man
