Brake lights not working on 85 D100 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 01-14-2012, 10:17 PM
KRam85 KRam85 is offline
Vehicle: 1985 Dodge Ram D100
Color: red
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
KRam85 is on a distinguished road
Default Brake lights not working on 85 D100
There's power to the brake switch. The brake lights worked briefly until I repaired the right rear turn signal. I had to run a new wire to that turn signal. Don't know if there is a correlation. All the other lights work but the brake lights. There's a wire harness underneath the hood that feeds wires to the rear of the truck. None of those wires are hot when the ignition switch is off. The brake lights should work with the ignition switch in the off position. I should mention that I did put in all new bulbs exactly like the ones I removed. This is extremely frustrating and puzzling. What do you need to know to help me? What sort of test do I need to run? How can I pinpoint the problem?
Old 01-15-2012, 11:04 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I'd take the time to check the bulbs again. They are only supposed to go in one way (1157 push in and turn to lock). But they sometimes go in the wrong way. One post on the side is closer to the base of the bulb than the other. They CAN go in the wrong way and seem locked. Check that the emergency flashers work with the headlights (parking) on.
If you hit the brake pedal on the 1st Gen while the flashers are on then both front lights will stay on bright as long as you have your foot on the brake.
