Old 01-15-2012, 11:40 PM
judnash judnash is offline
Vehicle: 2011 Ram 2500
judnash is on a distinguished road
Default Lift Options ( newbie bare with me )
I know there are probably numerous similar threads but please bare with me.
I have a 2011 ram 2500 slt big horn, using as work truck. Looking to do a lift, nothing to high, maybe 4-4.5" lift. I also want to level the truck, do not like rake, will i need it with the lift kit? Should i do the 2" kit? I hear the 2.5" kit makes the front end higher then the rear which i do not want. and to top it off i want to toss some 20-22" rims and 35" tires on her.
so my questions are which kits are best and will ride like stock? any advantage to the 4.5" lift over the 4" lift? will i need to re gear with 35" tires and big rims?
newbie questions i know, a lot of this i will just have to learn through experience but any input would be appreciated, and pics of your trucks as well, post em, give me some tips and ideas. thanks in advance.
Old 01-21-2012, 05:13 PM
Rep:4173
Some good questions there, hopefully someone can chime in here with some advice for ya!
Old 01-21-2012, 05:58 PM
Schmitz's Avatar
Schmitz Schmitz is offline
Vehicle: 2005 Dodge Ram 2500 4x4 QC LB
Schmitz is on a distinguished road
Best way to know weather the 2 or 2.5 is best for you is measure the difference between the front and back, most lift kits will level the truck pretty close if your wanting a little more height, I personally went with 6 inches on my 2500, because the price difference between the 4 and the 6 isn't much. And with 35s you shouldn't need to regear it would help but isn't really necessary
2005 Dodge 2500 4x4 QC LB Hemi, 6 inch lift, 37" Cooper Discoverer STT's, Bully Dog programmer, K&N cold air intake performance throttle body, true duals, debadged.... Soon to come 4.56s and wheels, maybe more lift.
1980 Chevy K20 4x4 9 inches of lift 37" Boggers, 402 BBC, 4 spd, D60, 14ff.
Old 01-22-2012, 05:42 AM
p71 p71 is offline
Vehicle: 2011 Ram
p71 is on a distinguished road
Buy a four inch lift kit and some bilstein 5100 adjustable coil over struts. Install lift kit. Micro adjust front ride height with bileteins.
Old 01-22-2012, 10:52 AM
Schmitz's Avatar
You can't get adjustable 5100 for a 2500
Old 01-23-2012, 01:29 PM
Raynval Raynval is offline
Vehicle: 2011 Ram 2500 4x4 Hemi ST
Raynval is on a distinguished road
Default Lifting 2011 2500
Is it a 4x4? I'll assume it is. Whats is the stock gear ratio?, probably a 3.73 or 4.10. Is it a Hemi or diesel? The disels weigh almost 1,000# more on the front and typically the better kits have different springs to compensate for the extra weight. What are you more concerned with, offroad ability, or looks and maintaining the capacity for hualing payload?
Pics of my 2011 2500 4x4 are here, http://www.ramforumz.com/showthread.php?t=98599&page=5 , read through this thread and you will get very good information about the various lifts (there are a lot) and tires for these trucks.
The first thing you need to know (and you may already) is most of the information on the forums is for a 1500, which does not translate for the 2500 models. The 2500 trucks already have a few more inches of lift than the 1500s, and the lifts are for different systems. I actually have a more detailed step by step install of my Rough Country lift if you go that route.
I do like a little rake, and don't like the Baja high front look. Most of our trucks are between 2" and 2 1/2" taller in the rear stock, but load them up with just 1000# or so and they sit level, or after some miles they loose a bit of that rake. I haul a trailer and typically have about 1500# (tongue weight included) in back when I'm offroad, so I wanted a little rake. My Rough Country lifted the front 4.5" (they called it a 5" lift) and 4" in back. It's perfect for me, as unloaded it's now about 1.5" higher in back, and when I hook up my trailer and load her like usual, she sits level to 1" lower in back. Most lift kits over 3" will include a lift block for the rear and most lifts will lift the rear 2" less than what they lift the front (to level it). Most of the 3" or less lifts only lift the front, with either a spacer to add preload on the front springs, or new longer springs. Most prefer new longer springs over compresing the stock ones, and progressive springs (more expensive) are typically prefered over single rate. The 3" lifts by Kore, Carli, and others often come with minipacks rear springs as well to replace the overload spring on the rear, they usually don't lift the rear much if any, but make them a bit more compliant for offroad. The one thing I didn't like about these systems is that they do not relocate the track bar, and after calling them, they really recommend an adjustable track bar to relocate the axle, which then starts making these kits really expensive for just what really turns out to be a 2.5" front only lift. I say if your going to lift it, then lift it and stick with around a 6" lift. The FabTech kit is a great kit, but they tend to be front high kits, I choose the other end of the spectrum with the R/C 5" kit which levels the least. Most of the otheres are between them, shooting for a level ride. I prefer a short arm kit, because I can go back to stock if needed, a long arm kit usually requires removal of mounts. On a new truck, you may have warranty issues, so being able to return to stock was better for me.
Other things to consider. Bigger rims give less sidewall height and are damaged easier in offroad conditions and can't be aired down as much if you get into something nasty, they can also increase the costs of the tires a lot.
You will need to reprogram your truck for bigger tires for your speedometer, the mileage computer and shifting, some have issues with the ABS systems with bigger tires as well. Again, this could cause warranty issues. You will need an alignment with any of these routes.
Old 01-31-2012, 01:38 PM
Rug 15's Avatar
Rug 15 Rug 15 is offline
Vehicle: 2012 RAM 1500 ST
Rep:53
Rug 15 will become famous soon enough
dang raynval thats alot of info. good stuff though. im new too but got a 1500. would love either a level... or a small lift. just for the occasional romp in the mud and overall look. any suggestions? (weather just level kit? or a 2" all around lift?) keep in mind trying to keep warrenty intaact.. lol
