Old 01-16-2012, 02:14 PM
kylehouse kylehouse is offline
Vehicle: none
kylehouse is on a distinguished road
Default 2500 towing
First post! Today I am going to look at a 2011 ram 2500. It's white, 4x4, crew cab 32,000 miles, 5.7 hemi. $30,500. The question is...why is the tow rating on it lower than that of the half ton. the three quarter ton's gears are the 3.73 and the half ton's are 3.92. Can that be the only reason? I need it to pull a gooseneck when I take my calves to the sale. The tow rating on it is only like 8,800 lbs. What to do.
Old 01-16-2012, 08:36 PM
Beaux's Avatar
Beaux Beaux is offline
Vehicle: 06 Dodge 2500 / 07 Dodge 3500
Rep:19
Beaux is on a distinguished road
Yeah, I'm a little miffed as to why my BIL's Nissan Titan 1/2 ton has a higher towing capacity than my 2500HD!
Old 01-16-2012, 08:58 PM
wbowyer wbowyer is offline
Vehicle: 2011 Dodge Ram 1500
Color: Inferno Red
Rep:71
wbowyer will become famous soon enough
Its because of the following:
2500= HD frame, suspension, and in general a bigger, heavier truck
Crew Cab= more weight
Short Bed= reduced weight carrying area (weight is forced over the rear axle instead of on the frame to distribute it)
4x4 = more weight to push around
3.73 gears = lower gear ratio
Now take the weight differences in the 2500 you have configured and subtract them from the difference in towing capacity and you'll see that its only limited because the hemi can only pull so much consistently.
I do have to ask, if you're pulling cattle around why wouldn't you opt for the cummins anyways? You can find used 06-07 5.9s with a straight shift in them for a great price AND if you have any diesel farm equipment you'll be able to run the OR diesel that your equipment takes if you "need" to. You can also build these trucks to be more powerful than the 6.7's with the addition of injectors and the fuel system (under 2k if you go for the best brands) and you'll have a truck that gets awesome fuel economy and can out pull anything else.
Just my .02, feel free to take it or leave it.
Old 01-16-2012, 10:56 PM
RTBenny RTBenny is offline
Vehicle: 2012 Ram R/T
RTBenny is on a distinguished road
Dodge has some weird tow rating systems for sure. I wouldn't worry at all about the chassis handling it. As for the engine, depending on your total weight, how often you tow, and where you tow to (mountains or flats), the Hemi may not be too good. I wouldn't want to pull more than 10,000 pounds with it ever. And then only maybe once a month or less. And even less in the mountains. Consider the Cummins if any of those are something you do.
2013 F-150 King Ranch 4wd 5.0
Old 01-17-2012, 01:12 AM
dixiejwo dixiejwo is offline
Vehicle: 2012 Ram 2500
dixiejwo is on a distinguished road
I think you might be confusing GVWR and GCWR. GVWR is the total allowable weight on the axles. GCWR is GVWR plus the trailer.
The GVWR of that truck is 8,800 lbs but the GCWR is 15,000. Max trailer is 8,500 with the 3.73 or 11,500 with 4.10s.
Read: http://www.media.chrysler.com/dcxms/..._HD_Towing.pdf
