Place your Ad Here!
Old 01-16-2012, 09:03 PM
rmchodgkins rmchodgkins is offline
Vehicle: 2008 Dodge Ram
Trim Level: Big Horn SLT
Color: Charcoal Gray
rmchodgkins is on a distinguished road
Default Changing spark plugs on 2008 Dodge Ram 4.7L
I changed the plugs about 36000 miles without any trouble and now need to change them again at 77000 miles but the 5/8" socket won't fit all the way into the spark plug hole now. Has anyone else experienced this problem and what did you do to fix it?
Old 01-18-2012, 07:27 PM
RamEZ RamEZ is offline
Vehicle: 2007 Dodge Ram Quad Cab
Color: Mineral Gray Metallic
RamEZ is on a distinguished road
Maybe you used a thin-walled socket the last time?
Don
Old 08-11-2012, 09:51 PM
bigmike19956's Avatar
bigmike19956 bigmike19956 is offline
Vehicle: 2002 Dodge Ram 1500
bigmike19956 is on a distinguished road
Definitely has to be a thin wall socket. Using the ribber insert helps to keep the plug in socket for retrieval and install.
Old 08-12-2012, 10:20 AM
lbartee's Avatar
lbartee lbartee is offline
Vehicle: 2008 Dodge Ram Quad Cab
Color: Inferno Red Pearl
lbartee is on a distinguished road
Had the same problem. Couldnt get a thinwall socket to work either. Had to take socket and grind the od with a Drimmel tool. Worked great after that.
Old 07-24-2014, 03:05 PM
Kustomblack1's Avatar
Kustomblack1 Kustomblack1 is offline
Vehicle: 2015 Ram 1500 hemi 4x4 crew
Trim Level: 1500
Color: Crystal Pearl black
Kustomblack1 is on a distinguished road
Default Thin wall is the tuff answer
This guy explains it the best
http://youtu.be/Wpj1zsQF2wM
lets just truck!
4.7l engine, 5/8" socket problem, spark plug change
