Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 01-16-2012, 10:57 PM
Redlongbed's Avatar
Redlongbed Redlongbed is offline
Vehicle: 2002 Dodge Ram 1500
Redlongbed is on a distinguished road
Default O/D Question
I have a 2002 Ram 1500 quad cab long bed with the 5.9, 4-speed auto, 3.92 gears and towing package. I remember someone saying on here one time that these transmissions will be destroyed if you tow/haul anything with O/D on. Well I have towed some fairly heavy loads before in the 5-7k pound range and I turned the O/D off because I knew the tranny would be under a lot of stress with the heavy loads. Well I just bought a 6X14' utility trailer that weighs about 1200 unloaded and I will be using it mainly to haul two, maybe three four wheelers and for occasional scrap hauling and landscaping work. I imagine I will be towing mostly in the 2-3k pound range. So my question is do I need to turn the O/D off when towing such a small amount of weight? I love the way the truck performs with the O/D off, but anyway I can try to save some gas mileage on this gas hog without destroying anything I will definitely do. Thanks for the help.
Old 02-17-2012, 03:27 PM
06 BigHorn's Avatar
06 BigHorn 06 BigHorn is offline
Vehicle: 2012 Dodge Ram
Trim Level: Express Quad Cab
Color: Deep Cherry Red
Rep:153
06 BigHorn has a spectacular aura about06 BigHorn has a spectacular aura about
Don't you have a tow mode? Mine I click the OD button once it goes into tow, a second time & it turns off the OD.
It's a truck, not a cream puff
Old 06-05-2012, 01:15 AM
LunchboxL1's Avatar
LunchboxL1 LunchboxL1 is offline
Vehicle: 2013 Dodge Ram 1500 Laramie
Rep:14
LunchboxL1 is on a distinguished road
If you have the the TOW/Haul option I would use that.....If you dont I would turn O/D off unless you are at crusing speeds on a flat highway where the transmission won't be shifting alot....
