Old 01-17-2012, 02:10 PM
Dysartsmoker Dysartsmoker is offline
Vehicle: 2012 2500 Laramie
Dysartsmoker is on a distinguished road
Default Interior light question
Just got my 2012 2500 Laramie traded a 2008 F250 when I turned the ignition off on the ford the interior light would come on but not in my new 2500. Is there a setting I'm missing or the ram does not have this option ???
Old 01-17-2012, 02:46 PM
Kinda forgot the headlights really are awful on bright anyone else have these issues
Old 01-17-2012, 03:13 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
i couldn't help you with the interior light question but i have heard alot of members complaining about the light output on the 4th gens but there is some mods that can help, hopefully someone who has done some will chime in
Old 01-17-2012, 03:21 PM
moparornocar72's Avatar
Rep:630
go to ur evic display if u have it, should be an option for a light delay and other options as well!
14.268 @ 95 MPH Full Trim
Old 01-18-2012, 05:33 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
I dont think there is one to turn the lights on when you turn the truck off... just when you open the doors.
As far as the ighting, yes many people hate the way these trucks have sub par lighting. HIDs are the most common fix. Check in the sub section down below and all your questions can be ansered
2011 Big Horn 4x4 -SnowWhite-
Old 01-18-2012, 10:07 AM
Rambunkshuss's Avatar
Rambunkshuss Rambunkshuss is offline
Vehicle: 2014 Dodge Ram
Rep:87
Rambunkshuss will become famous soon enough
Key off, interior light on, not an option with dodge trucks.
Opening your door is the only way you`ll turn on the interior lights.
(unless you manually turn it on/off by the dash light dimmer switch)
Kudo`s to ford and many others that have the interior "light on" option.
Only thing i wouldnt like about it, is the option to turn it off if i wanted too.
Headlights...
you can raise them by the adjusting screw under the hood
Start w/3turns clockwise to raise the level of them. It DOES help, but not by alot.
Dont bother with silverstar bulbs... wayyyyyy too pricey, and are no better.
The problem is the reflector`s in the headlight housing. They just suck.
Install HID with projectors, thats the only fix. (if done by a professional)
DO NOT just install the HID bulbs, they`ll create way to much glare w/out projectors.
Life`s tough, its even tougher if you`re stupid
Old 01-26-2014, 09:54 PM
MisterGDRam's Avatar
MisterGDRam MisterGDRam is offline
Vehicle: 2012 Ram 1500 Hemi
Rep:28
MisterGDRam is on a distinguished road
Where is that switch when you open the doors and lights come on?? Am I that blind and can find it??
2012 Ram 1500 Hemi Big Horn Edition
Billet Catch Can;Beg Rug Bed Liner
Old 01-26-2014, 09:55 PM
Rep:28
Originally Posted by Rambunkshuss View Post
Opening your door is the only way you`ll turn on the interior lights..
Where is that switch?
