Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 1st Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 01-18-2012, 02:17 PM
prostar19 prostar19 is offline
Vehicle: 2007 Dodge Ram 1500
prostar19 is on a distinguished road
Default Vent selector issue
I have a 2007 ram 1500 and the selector switch will move air between defrost and panel but will not go to the floor. Same thing happened with my 2003. Any ideas what I should check?
Thanks!!
Old 01-18-2012, 02:47 PM
65Arboc's Avatar
65Arboc 65Arboc is offline
Vehicle: 2012 Dodge Ram 1500 Laramie QC
Trim Level: laramie
Color: Black & Silver
Rep:148
65Arboc will become famous soon enough65Arboc will become famous soon enough
My 2006 had this happen twice, once while in warranty and again in the middle of last winter after out of warranty. First time cost me $0 next time dealer said it would cost $600.00 as they have to take the dash out. I covered the defrost vents with gloves and drove it that way till I traded it in Oct. There is a little plastic deflector that moves to direct the air (less than $10.00 part I guess), the rest is labor. Unless you are comfortable with removing the dash you are stuck with no heat or air on the floor.
Jim in Pa
No Mods Needed. Ordered it just the way I wanted it. Well, I did put a cabin filter in and de-badged the doors of the Ram 1500 things.
Old 01-18-2012, 03:23 PM
Well that's not good news.....
Thanks
Old 10-17-2012, 07:48 PM
MikeyInNY MikeyInNY is offline
Vehicle: 2006 Dodge Ram 1500 Quad Cab
Trim Level: Stock
MikeyInNY is on a distinguished road
I am having the same problem. Do you have the details of how it was fixed?
Old 10-17-2012, 08:11 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
i have heard that it is the blend door actuator...a small motor that moves the door...
Old 10-17-2012, 08:12 PM
Rep:2657
go to YOUTUBE
type in Dodge Ram Heating Problems
this will come up
http://www.youtube.com/results?hl=en...-8&sa=N&tab=w1
personally, i like the way it is fixed in the HeaterTreater Videos,( 3 part )
Good Luck
hope it turns into a simple fix
