Old 12-28-2012, 11:24 AM
osucowboys83 osucowboys83 is offline
Vehicle: 2013 Ram Sport
osucowboys83 is on a distinguished road
Default Cutting coils for 1/2 drop help
Just wondering if anyone has cut the coils up front for just a 1" lowering and in the rear cut the coils to lower it 2" to 2 1/2"? I really don't want a 2/4 look just something maybe 1"/2" lower stance from the stock look? If so how much of the front coil should I cut to lower it 1" and how much of the rear coils should I cut to get 2" or 2 1/2"?
Old 12-28-2012, 11:42 AM
Woodie12's Avatar
Woodie12 Woodie12 is offline
Rep:26
Woodie12 is on a distinguished road
I wouldn't cut any. Reason why is cutting your coil will affect your ride and will also put more strees on parts. Your best bet would be to save a lil cash and replace the coils with a proven lowering kit of some sort.
MOPAR = MO POWER
Old 12-28-2012, 12:03 PM
Rep:1385
Some coils are ok to cut, some aren't. The factory springs in the ram are not. That said, I cut my rears for a 1" drop in the back. I used RT springs as they are progressive and are nearly flat at the top, so there is no issue with cutting them.
I've seen others cut the regular springs(non RT), and although they haven't had any issues, it is very dangerous. The stock springs are not a type that is safe to cut.
There are also a few companies that make 2" rear drop kits. Maybe you'd be happy with that look?
Old 12-28-2012, 12:31 PM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
Explain the theory why the stock springs are dangerous to cut?
I've seen no reason at all not to cut them for a mild drop.
Old 12-28-2012, 12:34 PM
Rep:1385
This explains it pretty well:
http://www.eatonsprings.com/cuttingcoilsprings.html
Old 12-28-2012, 12:56 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Thanks for the info Sean, I knew not all but that article sure makes it easy to understand, Reps to you when the site lets me LOL
Old 12-28-2012, 01:44 PM
UNBROKEN's Avatar
Trim Level: R/T
Rep:123
It's safe to cut off the top of our springs both front and rear.
Many here have done it and I've done it for years on front springs of similar design.
Obviously you'd never cut a pigtail spring but maybe that's not obvious to everyone.
Use a chop saw or cut off wheel...never a torch.
Old 12-28-2012, 01:53 PM
Rep:1385
^that's really an opinion. It's not really "correct", but many do it. I wouldn't because the spring does not sit the same in the spring pocket/perch like it's supposed to. Whether you will have an issue, maybe or maybe not.
Old 12-28-2012, 01:59 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Trim Level: ST express
Color: Grey
Rep:195
Front springs will be fine (1/2 coil is about 1" on front, FYI). Rear springs are where it starts to get sketchy, if you want 2" or more of drop. I would cut the fronts, and get McGaughy's 2" rear springs, cutting them to taste if necessary. There are many threads on this site discussing this topic, search for them and read up!
Old 12-28-2012, 02:07 PM
UNBROKEN's Avatar
Trim Level: R/T
Rep:123
It may be an opinion but its based on years of experience on personal projects, friends projects and time spent running a custom shop. I've never seen a failure in 27 years of doing this stuff....not including idiots bringing stuff to me to fix after they heated or cut a coil with a torch.
