Catalytic Converter - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 > Exhaust
Exhaust 4.7L Exhaust Discussion
Old 01-18-2012, 09:01 PM
Spoobi's Avatar
Spoobi Spoobi is offline
Vehicle: 2003 Dodge Ram 1500
Color: Grey
Rep:20
Spoobi is on a distinguished road
Default Catalytic Converter
Hey everyone, i'm planning on getting my exhaust done soon and was wondering what the cons of getting rid of my cat would be? My truck is an '03 and i've heard that cutting off the cats really only affects anything newer than an '05, how true is this? Thanks.
Old 01-19-2012, 03:49 PM
trentowens92's Avatar
trentowens92 trentowens92 is offline
Vehicle: 2002 Dodge Ram 1500
trentowens92 is on a distinguished road
only issue you should have would be your CEL would come on,for the rear o2 sensor.thats easy and cheap to fix,i can explain if you decide to do it.also your truck will be louder.i plan to do this in the near future as well.
Old 01-19-2012, 04:01 PM
Spoobi's Avatar
Color: Grey
Rep:20
Thank you, I will probably do it if it's not going to affect anything other than the CEL. What is the fix for this?
Old 01-19-2012, 04:53 PM
Rep:2964
In California, any vehicle 1976 & newer, will not pass Smog without the Catalytic Converter, if it had one when built
Old 01-19-2012, 10:33 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Do you need to pass emissions? Do you care about the environment? You can cut the cat off, but late model cats are very free flowing and you gain little without them. I would leave them on on any late model vehicle. On older vehicles I would replace it with a aftermarket cat.
Sean
Old 01-19-2012, 10:44 PM
if you need to pass emissions,leave it be or get high flow cats.if not,i say cut them.it sounds alot better imo.
to fix it get a set of spark plug non-foulers(not sure on the size,but its the same as the o2 sensor)
take one of them and drill the hole out to 1/2 inch.screw that one on your o2 sensor.then,take the other,and screw over the one you drilled.
then you take the hole setup and screw it into where your sensor goes.
this acts like a spacer and makes less air get to the sensor and tricks it into thinking you have a cat.some say it doesnt work but it has been fine for me.no CEL
Old 01-19-2012, 11:09 PM
snrusnak's Avatar
Rep:1388
^that method has worked for me as well on other vehicles. (not that I'm for cutting cats).
Sean
Old 01-20-2012, 11:01 AM
some say it doesnt work but it has worked well for me, but with that said i do still have my cat,but it is a magnaflow high flow cat and was setting off my sensor,this cleared it up
Old 02-19-2012, 07:50 PM
artykatt's Avatar
artykatt artykatt is offline
Vehicle: 2002
Color: Gold
artykatt is on a distinguished road
http://www.energeticforum.com/renewa...n-foulers.html
