Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Old 01-19-2012, 07:10 AM
matt085's Avatar
matt085 matt085 is offline
Vehicle: 2009 dodge RAM SLT HEMI
Color: BLUE
Rep:59
matt085 will become famous soon enough
Default HOW TO: customized Trinity dash mount
hello,
this is my first mod writeup so its a simple one.
I used to place my diablosport trinity always in the left lower corner of my windshield with the suction mount but noticed some problems there. it always took away my attention off the road, it vibrated a lot because of the long mount arm. and most of all, it looks like a GPS, visable from the driverswindow and leaving round GPS-like marks on my windshield to attract scum. so it was more in the house then in my truck.
The best out of the way, easy to reach place i could find was under my 4wd select knob.
trinity mount before. think they only have two models, this one and a pod mount.
inside the plastic tube is a pretty thick alu rod. cut off the plastic at about 20 ribs.
cut or saw the alu rod leaving enough space, (mine was to short) leave at least 3/4inch sticking out of the plastic.
next I made threats in the rod using a threat make thing.
to come to this. bend it already the way you want it because you dont want to bend it to hard afterwards and crack your dash.
drilled a hole from the inside out and trimmed the inside with a dremel to fit the washer
watch out not to damage the theat by trying different nuts like i did had to redo it with a smaller size
finished with the cable coming out of the dash under the mount
turns out to be a good spot, vibrates a bit more then i tought, didnt know the bezel vibrated that much. but its a short arm so its not going anywhere.
let me know what you think or how you did it
Old 01-19-2012, 07:23 AM
MartinJD's Avatar
MartinJD MartinJD is offline
Vehicle: 2011 Dodge RAM
Rep:14
MartinJD is on a distinguished road
Very nice mod and write up! If I could tune mine I would have to use this idea.
Old 01-19-2012, 10:26 PM
Rep:3322
A very different customization, I like it; I just went with the pillar pod mount for mine.
