Oil Change confusion.. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 01-19-2012, 02:34 PM
TG1977's Avatar
TG1977 TG1977 is offline
Vehicle: 2011 Dodge Ram
Trim Level: Big Horn Quad Cab
Color: Deepwater Blue
TG1977 is on a distinguished road
Send a message via AIM to TG1977
Default Oil Change confusion..
So the book says I don't need to change the oil until like 7k but the computer came on today when I hit 3500... I'm sure its best to get it done now, but why the difference?? Also should I stick with reg oil or go synthetic? Will it make a difference since I pull a horse trailer? Recommendations appreciated!
Old 01-19-2012, 02:46 PM
bigreid's Avatar
bigreid bigreid is offline
Vehicle: 2011 Ram
Rep:23
bigreid is on a distinguished road
3500 miles haha, you're talking about the service record in the owners manual correct? That's just for all the stuff you have serviced on your truck in the period of time. And make sure you use synthetic, it helps in the long run
Project Diamondback
Old 01-19-2012, 03:19 PM
TG1977's Avatar
I have to have the dealer do the switch to synthetic right? Which synthetic do you recommend. I used Mobil 1 in my other suv's but they weren't doing any work.
Old 01-19-2012, 03:43 PM
ramoreno's Avatar
ramoreno ramoreno is offline
Vehicle: 2002 Dodge Ram
ramoreno is on a distinguished road
you can use reg oil for the next 3500 miles and then switch to syntetic, and the message from the computer is gonna came every 3500 aprox. miles, if you want to wait for the 7k, and dont look the message erase it. Just put the key in on position(dont turn on the truck) and pump the gas pedal 3 times.
Old 01-19-2012, 04:04 PM
selfserve217 selfserve217 is offline
Vehicle: 1994 Dodge Ram 1500
Trim Level: Laramie SLT
Color: Green
selfserve217 is on a distinguished road
I use castrol synthetic in my car (truck is too old for synthetic). I would recommend either castrol or mobil. Just stay away from pennzoil, as i've heard it tends to leave alot of buildup over time internally. I would even consider adding some Lucas to your oil changes, that stuff definitely helps in the long run as well. Hope this helps!
Old 01-19-2012, 04:41 PM
SilverHemi's Avatar
SilverHemi SilverHemi is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT Quad Cab
SilverHemi is on a distinguished road
Absolutely...... we did a study in college and found that penz left the most gunk crap by far..... now if u dont wanna pay for royal purple, then go castrol ive always used it and i swear by it.... oil has come a long ways tho...... like they say ur truck cpu is programmed that after u reset it regardless of oil type and what not it will come on every 3500 miles...... so do like we do and just reset the computer and push on.......
-Vote for your future- vote R3VOLUTION-
Old 01-19-2012, 04:44 PM
Rep:2962
It is never too soon or too late to change to Synthetic motor oil
let the dinosaur oil stay in the ground
I switched to Mobile One Synthetic & i decided to go with a good oil filter, i prefer WIX brand, who also makes NAPA GOLD & Carquest oil filters
I buy my Mobile One at Walmart, 5 quart jugs, it is almost $10 cheaper then any where else, i go to an auto parts store for the oil filters, i also use the K&N air filter
I change my oil at 5,000 miles, my light comes on at 2,800 miles, i just reset it, using the method mentioned above
I still have the dealership do the service, so they can't say that i neglected it, if & when something should go wrong
Old 01-19-2012, 04:59 PM
bigreid's Avatar
Vehicle: 2011 Ram
Rep:23
I personally will never change from castrol synthetic
Project Diamondback
Old 01-19-2012, 05:48 PM
s2welee s2welee is offline
Vehicle: 2011 Dodge Ram 1500 SLT
s2welee is on a distinguished road
Synthetic oil is still "dinosaur oil". Both conventional oil and synthetic oils are made from crude. Synthetic is just more refined and uniformed. There is a lot of misinformation about synthetic oil.
http://www.mobiloil.com/USA-English/...Motor_Oil.aspx
Old 01-19-2012, 06:06 PM
fishinf1's Avatar
fishinf1 fishinf1 is offline
Vehicle: 2011 Ram
Trim Level: st
fishinf1 is on a distinguished road
on the market right now the two top rated synthetic oils (according to studies, I'm no expert) are Penzoil Platinum and Valvoline Synpower. The old Penzoil that use to leave build up is no longer. Penzoil out preformed almost every oil out there. I don't run Penzoil I'm a Valvoline fan. Here is a good website for all the studies and performance tests of oils. http://www.bobistheoilguy.com/
