Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 01-19-2012, 11:11 PM
Dodgeramguy1993 Dodgeramguy1993 is offline
Vehicle: 2001 Dodge Ram 1500 Q.C 4x4
Color: Ugly :P
Dodgeramguy1993 is on a distinguished road
Default Can i fit these?
Hey everyone, new to the forum and just want to start of by saying, what a great site for good advice from everyone.
I have a question....I own a 2001 dodge ram 1500 Laramie quad cab ,4x4 wit the 5.9L
This past summer i recently installed 2.5" front coil spring spacers and 1.5" rear blocks. I also purchased another set of the other style ram OEM rims which are 16" and i believe they have 5" offset?
So here's the deal.....I was wondering if i could fit some 35's with no rub? and what size would that be? 315/75/16? someone told me i cannot go with that size on my rims? what do you guys think......thanks
Old 01-19-2012, 11:54 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
It'll be tight...you may have to do steering stops and rear of the front fender trim. Since you put on 2.5 inch spacers, I'd probably install some longer control arms from a 3 inch lift, along with an adjustable track bar.
Both these mods might give you enough because they'll recenter the front axle in the wheel and the axle under the frame. The rear should be ok.
The recomended lift for 315/35 inch tires is 5 inches. You'd be much safer with 33's
Oh..your stock gears and tranny will hate trying to turn those larger heavier tires.
Old 01-20-2012, 12:55 AM
Color: Ugly :P
would i be okay running 305/75/16 ? by "okay" i mean rub wise and not hard on my tranny?
Old 01-21-2012, 11:06 PM
nicraage nicraage is offline
Vehicle: 2001 Ram 1500 4x4, 5.2L
Color: Flat Black
nicraage is on a distinguished road
will the 315/75 fit on 8" wide rims?
