Old 01-08-2012, 09:45 PM
Meat Sammich Meat Sammich is offline
Vehicle: 2006 Dodge Ram
Meat Sammich is on a distinguished road
Default Feet Heat!
Fellas, I get very little heat down by my feet. Blend works great on all other settings. Feet heat seems to go toward defrost vents.
I hate cold feet!
Any guess on what may be involved here. Please don't tell me to tear the whole dash out, heh!
To clarify, blower works great. very little air velocity on the feet detting
Old 01-08-2012, 10:08 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
Has to be a blend door issue. Not sure if that's an easy fix or if you have to tear out the entire dash.
Big Red my old 2011 Sport
Old 01-09-2012, 04:10 PM
Big Dog 2008 Big Dog 2008 is offline
Vehicle: 2008 dodge ram
Trim Level: lariat
Big Dog 2008 is on a distinguished road
I have the same issue with my truck. Unfortunatly yes the dash has to come out to repair. It is an expensive and extensive fix. Dealer wants 1000 bucks others about 800. I found that if you poke around inside the duct work ( be gentle) the blend door can be opened to allow airflow. I got brave and found a piece of lathe about 14 inches long and put it in the duct to hold the door open onthe drivers side. Im hoping for a recall as this seems to be a common problem.
Old 01-09-2012, 04:52 PM
Rep:2657
Watch the Heatertreater videos on youtube, they explain quite well what is involved, it may be a simple fix
http://www.heatertreater.net/dodge-ram-02-08
Also on YouTube several other people have their particular issue & fixes
just click this
http://www.google.com/search?sclient...w=1024&bih=550
Old 01-09-2012, 06:52 PM
whipinalluponya's Avatar
whipinalluponya whipinalluponya is offline
Vehicle: 2002 dodge ram 1500
Color: graphite gray
whipinalluponya is on a distinguished road
yea, check out the heatertreater and the videos on youtube.
i bet that its not the blend door because that controls how much hot or cold air comes out of the vents, so if you can still control that then its probably not the blend, which is good news.
there is some video on youtube which can help you locate the floor vent doors so you may want to search for that.
hope you can get this fixed.
I got to use my AK........... today was a good day.
Old 01-17-2012, 04:43 PM
Thanks fellas!
I get hot air at the floor, just doesn't blow much air. As if there's a stuck door or something.
Old 01-19-2012, 02:39 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Sounds like mode door 2 failure to me. Yes, the blend door controls the hot/cold air temperature mix so it's not that. Mode door 1 routes air away from the main front vents to the second part of the system. Mode door 2 then routes the air to either the defrost or the floor. Mode door 2 failure always results in air to the floor being blocked. The good thing about that is you still have defrost (gotta see!). The bad thing is, yes, a large portion of the dash has to come out to fix it. Unfortunately, mode door 2 is the only door that heatertreater does not have a simple fix for. Best I recall they do have a fix for it that is simpler than the dealer but still nowhere near as simple as the other doors. From the heatertreater site...."Most people choose to wear two pairs of socks rather than fix mode door 2".
Old 01-21-2012, 08:53 AM
al2ride al2ride is offline
Vehicle: 2012 Longhorn
al2ride is on a distinguished road
I hate cold feet!
I was just about to post the exact same problem. It just started a few days ago. Plenty of hot air through the other vents, but it won't blow through the feet vents. My wife loves it because she loves heat blowing on her face, but I hate it. Really sucks, my truck only has 60k miles on it. I'd hate to have to remove the dash to get this fixed.
If this is happening to a lot of Ram customers, and from what I have researched it does, then a recall should happen. Don't hold your breath on it though.
Old 01-21-2012, 04:33 PM
Rep:367
As I said above, classic symptom of mode door 2 failure. And yes, Dodge should have performed a recall but no, they aren't going to, lol. This is at least a six year old problem and if they haven't yet, they aren't going to.
