Old 03-10-2012, 07:38 PM
Grubrunner's Avatar
Rep:3883
Originally Posted by 464 View Post
Hey thanks for the offer. Yeah I'd like to know which welding process he used and the type of filler metal used if you can. Thanks, and your setup looks good. The guy did a good job.
I think Crash addressed it.
Anyhow....
Below is a cellphone [My Droid] clip I uploaded to YouTube a couple of days ago of my exhaust.
Not the most accurate depiction as far as what I'm actually hearing everyday [sounds a little louder & throatier than what you hear] but it gives you an idea.
Grub out!
Old 03-10-2012, 10:20 PM
2010 ram 2010 ram is offline
Vehicle: 2013 Ram CrewCab 1500 4x4 8spd
Trim Level: SLT Longstar
2010 ram is on a distinguished road
I am selling my Mangaflow cat back part# 16869. it only has 12k on it i just wanted to go louder i, looking to get 550 + shipping pm me if interested.
Old 03-11-2012, 03:53 PM
catalystram catalystram is offline
Vehicle: 2010 DODGE RAM 1500
Trim Level: SLT CREW CAB 4x4
catalystram is on a distinguished road
Default Transition Pipe Question
All - thanks for all this good information on exhaust mods. I am a beginner, so please pardon my ignorance. Seems like everyone is using the Magnaflow Tru-Y pipe with the Magnaflow (16869) Cat-Back, but is it possible to use a Tru-X pipe with the same Cat-Back? Seems to me that would increase all-around performance, but I am probably completely missing something. Any thoughts/comments would be appreciated. Thanks.
Old 03-11-2012, 08:46 PM
Grubrunner's Avatar
Rep:3883
Below is a reply I posted on another forum.
It may help you.
Here's some information you may find usefull -
H Pipe:
An H pipe helps equalize the exhaust pressures between the two banks of tubing as the hot gases and sound waves travel down the tubing. This, in effect, relieves the exhaust pressures as they travel through the H tubing, generally creating an increase in torque. This will also give an added sound reduction when the sound waves combine inside the H tubing.
X Pipe:
An X pipe will actually help to scavenge exhaust pulses from one bank as the opposite exhaust pulse passes through the X, thus creating a vacuum effect at the valve, resulting in a cleaner burn in the cylinder. This generally equals added torque and, like the H pipe, a reduction in sound as the sound waves combine in the X pipe.
Y Pipe:
The Y pipe, which works well on several applications, utilizes a dual exhaust off the manifolds/ headers and runs back a specified distance, then the two pipes enter the Y pipe and become one larger pipe. This Y helps each bank to scavenge the other as the pulses travel down through the Y and are joined together into the single common tubing. This creates a vacuum in the exhaust valve, resulting in a cleaner burn in the cylinder. A sound reduction is also achieved as the sound waves combine in the Y pipe.
Personally, I've had both in the past and the biggest difference I've found between H & X pipe is predominantly sound. As long as all things are equal, there's no significant difference in performance between the two.
Anything other than that horrid OEM Y-pipe on the Rams is a gain IMHO.
I went with a Magnaflow 10778 Y-pipe.
Very happy.
Hope this helped.
Grub out!
Old 03-11-2012, 10:01 PM
Default Y-Pipe
That definitely helps. Thank you for the time and info.
Old 07-05-2012, 02:43 AM
blackram12's Avatar
blackram12 blackram12 is offline
Vehicle: 2012 Dodge Ram
Color: Black Pearl
blackram12 is on a distinguished road
Great write up.
12' Dodge Ram Sport 1500 4x4
Old 07-05-2012, 08:38 AM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
i went from a flowmaster super 44 to magnaflow and i tell you what, the difference is very noticable! love my 14!!
-Pat-
Old 07-17-2012, 12:05 PM
DClig10 DClig10 is offline
Vehicle: 2009 Dodge Ram
DClig10 is on a distinguished road
The pipes look and sound awesome...... Of course another thing on this damn site that I want done ASAP!! But the next MOD for me will be the nerf bars..... Then the pipes!
Old 08-18-2012, 07:35 PM
SilentService SilentService is offline
Trim Level: 1500 Crewcab
Rep:49
SilentService is on a distinguished road
Quick question, can I just get the muffler and y pipe and replace just those or is this system more beneficial, why would have to change the already existing dual exhaust from the muffler back?
Old 08-18-2012, 08:40 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
you can def just remove and replace those 2. the factory pipe is stainless so no reason to get rid of it unless you are doing something custom like rerouting or whatever
