Old 02-22-2012, 02:43 PM
feelit2's Avatar
feelit2 feelit2 is offline
Vehicle: 2012 Dodge Ram laramie
Trim Level: laramie
Rep:19
feelit2 is on a distinguished road
Just installed the same set up and have a terrible drone between 1800 and 2000 RPM. I wonder if it has something to do with how the pipes are routed. He routed the driver side over the cross member and across the back of the transmission instead of across the pan in front of the cross member.
2012 Dodge Ram 1500
Laramie 4x4
Old 02-22-2012, 05:17 PM
feelit2's Avatar
Trim Level: laramie
Rep:19
I went back to the muffler shop and had them reroute the pipe from the driver side. Still have the drone but it’s not as loud and no longer vibrates under my feet. I made an appointment to have under coat and rust proofing tomorrow. I’m hoping to bring the noise level down just a little more at cruising speeds.
I can say without a doubt that adding the Vararam CAI, magnaflow 16869 cat back, 10778 y connection increased my MPG. Before 12/17 – After 15/21.
2012 Dodge Ram 1500
Laramie 4x4
Old 02-23-2012, 02:17 AM
Grubrunner's Avatar
Rep:3883
Originally Posted by 2BlueCrew View Post
Y-pipe question: How hard was it (for your exhaust guy) to get the pipes "to" the Y-pipe? As @AzHunter noted in a different post, it takes work to get the output of the Cats past the support bar. Did this present a challenge or did (or would) a good exhaust guy breeze through this?
He never mentioned ANY problems.
I asked him how the install went when I went to pick it up and his exact reply was.... 'Not a problem.... everything went together nicely.... it's a top notch system.... typical Magnaflow.... I just spent a little more time lining the tips up because I know you like them sitting almost flush with you rear bumper..... apart from that, it was great'
Sorry I couldn't help.
Grub out!
Old 02-23-2012, 02:20 AM
Grubrunner's Avatar
Rep:3883
This suprises me.
Apart from the CAI, and my Y-pipe being mounted a slightly differently then yours, we have a near identical setup.
I have absolutely no drone.... nothing!
Grub out!
Old 02-23-2012, 02:25 AM
Grubrunner's Avatar
Rep:3883
That's very impressive.
I just turned over 2K and I'm hovering around 16.7 MPG in the city and just got back this evening from a 300mile round trip that was 95-percent interstate. My MPG - following the trip - now reads 23.8 as it sits.
I'm more than happy.
PS: I always run either Shell or Exxon 89-grade.
Grub out!
Old 02-23-2012, 02:28 AM
Grubrunner's Avatar
Rep:3883
Let us know how this pans out.
Grub out!
Old 02-23-2012, 07:45 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
I'm a recent Flowmaster to Magnaflow convert as well and I only have a SI/SO muffler swap with SS tip. I love the way it sounds and I too have noticed that the truck seems to have a little more low end oomph. My EVIC is also showing a slight increase in MPG as well but I'm watching that to see if it is just a fluke or an actual gain.
Old 02-23-2012, 01:33 PM
yukonhemi yukonhemi is offline
yukonhemi is on a distinguished road
thanks for the post review i also have that cat back set up and it is great no drone nice tone fit and finish i run magnaflow on my 71 chev as well
Old 03-07-2012, 02:48 AM
feelit2's Avatar
Trim Level: laramie
Rep:19
Default Catback tips
Grubrunner,
How did you get the tips tucked back under the bumper?
2012 Dodge Ram 1500
Laramie 4x4
Old 03-07-2012, 11:15 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
it's all about the installer..they can do anything... that is a perfect fit regarding the tips..
