Old 01-27-2012, 09:01 PM
Holleywud's Avatar
Holleywud Holleywud is offline
Color: Austin Tan Pearl
Holleywud is on a distinguished road
^I don't know why people think installing these units is an hour or couple hour job...I've never done it but am pretty sure it requires pulling the axles, which alone is probably an hour job.
I think it will take that long because it will. I'm a certified Master Technician with over 20 years of experience. Pulling off a diff cover and popping out a couple spider gears isn't exactly what I would call difficult. When the manufacturer says that it can be done by the average Joe in a couple hours, you have to figure that a professional can do it faster and better. So don't lump me in with the rest of the crowd. Thanks.
Old 01-27-2012, 10:48 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^hey man I'm not trying to be rude at all. There is definitely a difference if you know it in and out and the everyday guy doing it on a saturday over a few beers or whatever. But don't you have to pull the axles? Shoot it would take me 30 minutes just to get the truck jacked up and wheels off...
Sean
Old 01-28-2012, 05:33 PM
Holleywud's Avatar
Sorry, sometimes I take it for granted having a lift, airtools and factory information at my disposal. You don't need to pull the axles all the way out if you don't want to. Just enough so that the spider gears come out. Read lots of positive reviews about the Powertrax No-slip on 4x4 pages. Around $500, it seems like the most logical choice to me. Plus, if the rearend starts getting noisey, put the spiders back in and head to the dealer..
Old 01-28-2012, 05:42 PM
Holleywud's Avatar
Sorry. You best bet is to go to the parts department at the local dealer and ask.
Old 01-28-2012, 06:12 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
Originally Posted by dig View Post
HI: Can anyone give me the OEM Parts number for the 2010 Ram 1500 LSD Differential Assembly. Thanks.
Does this help?
http://www.drivetrain.com/parts_cata..._pinioins.html
You might want to try contacting Mopar Online Parts, they may be able to help you out!
Old 01-29-2012, 11:10 AM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
Easy there! Nobody had any idea you were a technician and there isn't anything listed in your profile that would give that indication. I don't think he was commenting on your skill anymore than he was comparing it to what he thought it would take him to do the same job.
Old 01-29-2012, 06:28 PM
GearHd6's Avatar
GearHd6 GearHd6 is offline
Vehicle: 2010 Ram 1500 CC
Color: Mineral Gray
GearHd6 is on a distinguished road
Is adding the LSD just a matter of swapping out spider gears or does the whole chuck/differential need to get changed like most applications would? If that is the case then you have to switch the ring gear to the new diff then you have to set up the gear pattern all over again. Pinion depth would remain fine but you'd have to set up the backlash and pattern all over again. Than can get time consuming if you haven't done it before.
Old 01-30-2012, 07:42 AM
Holleywud's Avatar
Adding an LSD is a lot more difficult than adding the locker that I was referring to. The locker just replaces the spider gears and stays inside the factory case that the spiders stay in. The lsd would require removal of the ring gear and bearings. Then the rearend would have to be set up all over again to compensate for the new parts.
Old 01-30-2012, 11:46 AM
GearHd6's Avatar
Color: Mineral Gray
I got my build sheet from Dodge this morning, very quickly I might add seeing I just emailed them late last night. I'm very happy to find that my truck has the 3.92's with Anti-Spin.
Old 01-30-2012, 03:24 PM
rinkerman rinkerman is offline
Vehicle: 2010 Crew Cab
rinkerman is on a distinguished road
Unfortunately most of us assumed lsd would be standard - my truck is a Laramie package & still no lsd. My 2002 SLT 4.7 2 wheel drive had it. Live & learn.
