I am going to be changing my transfer case fluid this week. It seems like a pretty straight forward process. Should I warm the fluid before changing it, would normal driving for 10-15 minutes do this?
no need .there are 2 allen key bolts 1 drain 1 fill,make sure you take the fill bolt out first because if you take drain bolt out and drain and have trouble getting fill bolt out then = trouble,jus sayin.
