Old 01-22-2012, 06:03 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Question Plastic intake manifold porting??
Has anyone heard of the plastic manifolds being ported? Is this even possible???
I would like to see if the throttle body opening could be enlarged to 85MM or if an aluminum 6.1 manifold is a better option. Thanks!
Old 01-22-2012, 06:12 PM
moparornocar72's Avatar
Rep:630
The only reason i say no to the porting that it would be almost impossible it seems to get all the ported areas smooth again as they are factory. Also when porting the area, the heat produced when cutting/grinding could cause the plastic to be weak. In my opinion I would go ahead and find a 6.1 intake manifold. Esp. if u plan on boosting etc later on. I would esp. be worried about the plastic intake manifold with boost on it after porting. It may drop the amount of boost the intake could withstand. good luck to ya bud!
14.268 @ 95 MPH Full Trim
Old 01-23-2012, 01:07 AM
Ghostknife's Avatar
Ghostknife Ghostknife is offline
Vehicle: 2013 Dodge Ram
Color: Grey
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:51
Ghostknife will become famous soon enough
go with the 6.1 esp if you run nitrous
Old 01-23-2012, 04:55 PM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
also dont forget
if you have a 85mm throtle body and match intake but your gasket is not open big enough,...
so you would also need a biger gasket, bore to 85mm
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
Old 01-25-2012, 10:10 AM
Rumpelhardt Rumpelhardt is offline
Vehicle: 2005 Dodge Ram 1500
Rumpelhardt is on a distinguished road
I didn't think porting other than port matching was really of much benefit in a dry intake. I could be wrong though.
manifold porting plastic
