Old 09-16-2013, 12:21 AM
danno123 danno123 is offline
Vehicle: 2010 Ram 2500
danno123 is on a distinguished road
This unit has the mounting tabs on the side so it is a straight forward install. I am beginning to wonder if it is a corrupt hard drive. Either that or the unit is dead. I am going to look for a disk image and see if that works. Andy I am scratching my head trying to figure this out and came out the same as you. This should be an easy swap. I'll keep you posted. Thanks for the help.
Old 09-20-2013, 12:28 PM
My bad guys. Needed to disconnect the batteries before trying to install this unit. Everything is working as it should. I now have a 2010 Ram 2500 with a 2012 RHR operating fine.
Thanks for all your help!
Old 09-20-2013, 10:15 PM
astroman54's Avatar
astroman54 astroman54 is offline
Rep:52
astroman54 will become famous soon enough
Enjoy the new radio!
Andy
Andy
2009 Dodge Ram 1500 Sport Deep Water Blue Crew Cab Hemi 4x4
Old 04-11-2015, 12:33 PM
Jrileyso6 Jrileyso6 is offline
Vehicle: 2012
Trim Level: Big horn
Jrileyso6 is on a distinguished road
I'm want add the rhr730 to my 12 ram that has the res130 radio with Sirius but no phone has anyone attempted this? I've no phone button on steering wheel and No mic.
Old 04-14-2015, 09:50 PM
astroman54's Avatar
Rep:52
It should work, just that you won't be able to use the buttons on the steering wheel because you don't have them. No worries, they didn't have them on the 2009 steering wheel either.
You will need a microphone, but it doesn't necessarily need to be the one in the rear view mirror. There are others available. Take a look at oemautopartsco.com. They sell a microphone by itself that can mount pretty much anywhere. If you do want the rear view mirror, there is a different cable assembly than I have listed that lets you install it, and you will need to connect it into a power line (cigarette lighter wire) for power to the mirror. Again, make sure you have a high speed buss model radio.
If I'm not mistaken, the Sirius radio antenna on the 12's are dual band, so you just will need to hook up the one connector that's already on your current radio. You will find out if it isn't after you hook it up because it will not find your current location but boot up at the last place the radio was powered up.
Andy
Andy
Old 04-14-2015, 10:34 PM
Mopar Big Horn's Avatar
Mopar Big Horn Mopar Big Horn is offline
Vehicle: 2011 RAM 1500 crew cab 2wd
Color: PR4 Flame Red
Rep:139
Mopar Big Horn will become famous soon enoughMopar Big Horn will become famous soon enough
astroman54 is spot on. You can upgrade to a RHR as long as it is a high speed. I have upgraded the radio in my RAM from RES- RBZ- RER, it is easy to switch out the radios. As far as the mic, like astroman said you can buy just the mic (my mic is installed on the overhead console on the front driver side).
The antenna thing I always seem to see different answers. My 2011 RAM has the dual band sat radio & GPS antenna but it would not work with the RER. The RER has 2 separate plugs for sat radio & GPS, not sure about some of the other nav radios, but with it plugged into the sat radio it would only work the sat radio and didn't do anything plugged into the GPS. There is a jumper cable that works for the dual antenna that plugs into both sat radio & GPS plugs but it was on the expensive side, so I went with just the GPS antenna (much cheaper) and all is good.
Check my mod list.
Old 04-15-2015, 11:02 PM
astroman54's Avatar
Rep:52
Big Horn is correct about the RER having two separate inputs, one for Sirius and one for GPS.. The RHR however only has one input connector for a combined antenna.. Since I bought a RHR, it was easier (and probably cheaper) for me to change my single band Sirius antenna for a dual band than to figure out how to combine two antennas into the one input.
One thing I wish I could add is the two buttons one for phone and one for voice control to the steering wheel that the newer models have.
Anyway good luck with your project!
Andy
Andy
Old 05-13-2015, 11:29 PM
Rep:139
Andy
Good to know that the RHR works with the dual band antenna. I just bought a RHR for me from a member and am going to put my RER in my wife's 2011 Grand Cherokee, thought I would have to get a GPS antenna but not now.
Check my mod list.
Old 05-15-2015, 09:51 AM
astroman54's Avatar
Rep:52
Just a word of caution.. The 2011 may or may not have the dual band antenna.. I thought that they switched over in the 2012 model year.. If you do install and the GPS doesn't seem to find exactly where you are (in my case the GPS said I was in Texas when I was in NJ.. Then you will need to swap out the roof antenna with a newer one. IT will move you along the map as you drive because the RHR has internal inertia detection which takes over in tunnels and such when it looses GPS satellite reception.
Andy
Andy
Old 05-15-2015, 12:40 PM
Rep:139
Andy
Ok thanks for the heads up. I was told I have the dual antenna so hopefully they are right. Do you know if the RHR from a 2012 will a security code? Do you get so many tries to enter the code before it locks you out? If I try using the 0000, 1111, 1234, and so on....
Well I got the answers to my question. Just put the radio in and tried the basic codes and they didn't work, after 5 tries you have to wait 30 minutes. So looks like I will be making a trip to the dealership tomorrow.
Check my mod list.
rhr mygig installation
