4wd issue? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-23-2012, 12:52 PM
TG1977's Avatar
TG1977 TG1977 is offline
Vehicle: 2011 Dodge Ram
Trim Level: Big Horn Quad Cab
Color: Deepwater Blue
TG1977 is on a distinguished road
Send a message via AIM to TG1977
Default 4wd issue?
So after riding yesterday I go to park my trailer and all I do is slip,fishtail and jack knife in the snow. 4 lock and 4 lo made no difference. Rear wheels spin but the fronts weren't engaging at the same time. Then they'd engage and disengage.
My friend had to pull my truck and trailer with his Chevy to get it in a better spot so the trailer could be parked.
What the heck? Brand new truck and the 4wd isn't engaging?? Or is this how the Dodge 4wd works?
Old 01-23-2012, 02:15 PM
doug713's Avatar
doug713 doug713 is offline
Rep:33
doug713 is on a distinguished road
I dunno girl, sounds like something aint right. My 4 wheel drive worked awesome. That was my 05 ram though. My 11 ram is just 2 wheel drive and I was wishing this last week that I had gotten the 4 wheel as I was in our cabin in the mountains (Galinburg, TN). Let us know what you come up with and if you have to end up taking it to get checked out..
Old 01-23-2012, 03:05 PM
thevike93's Avatar
thevike93 thevike93 is offline
Vehicle: 2011 Ram 1500
Color: Grey
thevike93 is on a distinguished road
Sounds like something isn't right there. I've used my 4x4 a lot recently with some of the snow/ice we've been getting in MN. It takes a few seconds to engage though. Good luck!
Old 01-23-2012, 06:54 PM
herc herc is offline
Vehicle: 2011 Ram 1500 Quad Cab 4x4
Rep:21
herc is on a distinguished road
Does your selector have a 4Auto setting? If so, it sounds like the same thing I'm experiencing. I'm suspecting that on mine, the actual lockup isn't happening in 4Lock and it's stuck in 4Auto. So, when the rears spin enough, the fronts will grab, but they aren't always engaged like they SHOULD be in 4LOCK.
I haven't had a chance yet to get it in to the dealer to confirm, but I'd be interested to find out how yours turns out.
Here's another thread on the topic: http://www.ramforumz.com/showthread.php?t=101407
Old 01-28-2012, 02:43 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Something is not working right. When you select 4WD, you should have power to the fronts with no hesitation. The only 4WD mode that has hesitation, is 4WD Auto mode, as it does not shift in the front axle until it detects slippage in the rear, and even then, it shifts in very quick.
A trip to the dealer is warranted.
brad
Interested in one of my mods?
Old 02-01-2012, 12:17 PM
strider67 strider67 is offline
Vehicle: 2011 1500 ram
Trim Level: laramie
strider67 is on a distinguished road
I have a 2011 laramie have the same problem, the dealer tells me its normal there is some kind of electronic clutch that engages the front. let me tell you its the shits for goin down a icey hill when the front tires lock up and the back keep pushing.
Old 02-04-2012, 02:07 AM
brad12kx's Avatar
Rep:2581
This is true in the case of '4WD Auto', but NOT in the other 4wd modes. It your experiencing this the NON-auto modes, something is wrong.
brad
Old 02-15-2012, 10:57 AM
TG1977's Avatar
Ok, so after reading the manual and being in the mud again last weekend, I attempted to get into 4low again. The maual said I hve to hit the neutral button then shift into 4lo. Well the neutral button won't light up. I did it at a slow roll. I did it in park in drive and in neutral. Darn thing refuses to light up.
Am i doing something wrong or do I have to go into the dealer and play the stupid girl then give them hell when I get the runaround?
Old 02-15-2012, 12:08 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
i have never used 4 low, butmy 4wd seems to work fine. turn knob past awd and after a few feet the 4wd kicks in and all is good. have you all checked the fluid level in the t-case?
Old 02-15-2012, 12:19 PM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:368
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
i would go back to the dealer,.. but before try this if you didnt arlready
mine dosent have the auto mode but i can shift in 4x4 in any speed , and in 4x4 low without the neutral button option,.. but in neutral(shifter in neutral) ,...
maybe you should try this , at dead stop,put your shifter in neutral, press and hold the brakes then select the 4x4 mode you desire
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover, powerstop brake kit.
